Results 1 to 8 of 8
Reload Thread: Please help! Confused!
    Superjimbo31's Avatar
    Superjimbo31 is offline Junior Member
    Jan 2004
    CLeveland
    Well i did RECIEVE 2 sony 3way 6x9s for Christmas and im a little shocked here. Normally i would expect some 6x9s to throw out some pounding bass...alas i dont have nearly any! Here is the question i have, btw i also have the Sony headunit (fold down face plate, don't have the model number handy but if it helps someone let me know!) Well when i went to install the speakers there were 2 sets of wires, and the new speakers i have only have one set. I don't kno what any of this means, so i just installed the one set. I have a set of extra wires hanging there, and when i tested them they are both hot, there isn't a hot and a ground not sure what that means. Its a 1995 grand prix if that helps... Is there any special way to install 6x9s? Should i splice all these wires together? Can someone help me start from the top if this didn't help.
    So there is practically no bass at all, very very odd, and when i use the bass modifier on my head unit it really doesn't do much at all either. I have heard some stock speakers with more balls than this! Are they just ****** speakers or what is goin on here?
    nosaj070's Avatar
    nosaj070 is offline CarAudio.com Veteran
    Feb 2003
    Chicago, IL
    27
    2,394
    Re: Please help! Confused!
    To answer your question yes they are ****** speakers. But there are a few things you could check, make sure the speaker is sealed tight against the deck (all screws are tight). Also if that doesn't help, try out the other speaker wires that you have there.
    Alpine CDA-7995, A/D/S 3 Series Comps, ED 8A, SoundStream Reference 604, 98 Civic Sedan
    AIM: nosaj070
    Jan 2004
    CLeveland
    Well i can't change my headunit, but i can take the speakers back. Do you suggest anything in particular?
    Bumpin-dah8o8's Avatar
    Bumpin-dah8o8 is offline nissan grease monkey
    Dec 2003
    Honolulu, HI
    27
    286
    you should try tracing the second set of wires, or you could take the 6x9's back out and connect it directly to your H.U. and see what happens.
    sumone's Avatar
    sumone is offline CarAudio.com Veteran
    Dec 2003
    Midwest
    3,416
    I think it might it be the phasing problem where the left + right together cancels out some frequencies.
    Do you get bass if you pan hard to left, bass when you pan hard to right, but when panned center, there's less bass?
    Reverse the wires[put the - wire to the + wire, and vice versa] on one speaker I think solved for me when I discovered this bass cancellation, after I got a head unit installation from Best Buy. It was funny how I was telling him what the problem was...
    nosaj070's Avatar
    Feb 2003
    Chicago, IL
    27
    2,394
    Look into infinitys, alpine are ok. Thats about the best you'll do at your local bb or cc.
    AIM: nosaj070
    Redford's Avatar
    Redford is offline I get angry when Im sober
    Jun 2003
    Amherst, MA
    28
    405
    if you're willing to spend more... polk/momo speakers are pretty much the best at Circuit City... they sound much better than the Infinity Reference speakers IMO, plus they will play quite a bit lower.
    If you got em at Best Buy... don't know what to tell you, since I don't really know what they carry there. I know they got a lot of RF but I don't know those at all.
    1995 Camry LE 4 Cylinder Automatic Sedan
    Green Silver Pearl Metallic Clearcoat and/or Silverleaf Metallic
    No performance mods
    Clear bumper lights
    Clarion DXZ835MP
    Boston Acoustics ProSeries 6.53 in doors and Q-Logic kicks
    Polk/Momo 4 channel amp
    Spddracer's Avatar
    Spddracer is offline Sounds Goooooood
    Mar 2002
    Ohio
    45
    1,345
    15
    Quote Originally Posted by Superjimbo31
    Did you run the wires from you Head unit to your new speakers ?
    You should have a pair of wires for each speaker . What I mean by this is that each wire has 2 wires in it . One for + and one for - You would want to run each wire from the HU to the speakers .
    Do oyu have the owners manual for your Head Unit ? You may want to read the installation procedure . It would help tremendously I think !
    1990 300ZX Stage IV Twin Turbo
    Pioneer Premier P940MP
    CDT HD 6.5" Comps
    JL 300/4 Active
    (2) PG Ti10d
    Directed 1100d
    "WORK HARD.....
    PEOPLE ON WELFARE DEPEND ON YOU"
  1. confused on ohms
    By marleyskater420 in forum Wiring, Electrical and Installation Help
    Last Post: 02-06-2004, 09:59 PM
  2. HELP CONFUSED ON WIREING SUBS< HELP PLZZZZZZZZZZZZ
    By johnjacab in forum Subwoofers
    Last Post: 12-25-2003, 01:33 AM
  3. Im sooo confused!
    By ackinum6910 in forum General Discussion
    Last Post: 12-19-2003, 08:39 PM
  4. Confused newbie
    By MadSkillz in forum General Discussion
    Last Post: 12-06-2003, 08:39 AM
  5. Really confused about wiring to 2 ohms
    By RFosgateSTL in forum Subwoofers
    Last Post: 10-25-2003, 01:44 AM
