Results 1 to 14 of 14
Reload Thread: Suggestions for 8"-10" Midwoofer
    got_focus?'s Avatar
    got_focus? is offline Skeet Skeet Skeet
    Feb 2007
    Loveland, CO
    36
    1,549
    Icon32 Suggestions for 8"-10" Midwoofer
    Current setup -
    Memphis Big Belle amplifier
    Kenwood DDX7017
    ID HLCD Horns
    AudioControl DQXS
    Sundown e8 (x2) in a transmission line box (soon to be sa-8's)
    Looking for something that will keep up with the horns, but offer superb quality at high volumes. Seeking incredible midbass as well. I will be using a 8"-10" driver in my door, fiberglassed obviously, using the door as the enclosure. The doors are sealed except for the rubber flap on top where the window meets as well as the vents on the bottom side of the door to let water out.
    I was thinking something along these lines -
    Parts-Express.com:Morel CAW 938 9" Cast Frame Woofer | caw938 mw-265 mw-266 mw265 mw 265 6 inch woofer mid woofer midbass 6" woofer poly cone shielded woofer
    But open to all suggestions!
    2009 Nissan Sentra
    REFS - kickerlivinloud, stevew007, jellyfish420, Packerfan, FinalWolf, Bumpncarstereo, subingncali, bigmurf127, 1loudsuv, NhustlaR, violentrapture, toaster, thunder9500, Ecko072Unltd, kickinaudio, LivinLife, PV Audio, JDizzle, 5thgenaccord, krouchchocolate, duece212, PBateman, 22mountaineer, ProjectPechkin
    I would drag my cock through a mile of broken glass just to hear her fart through a walkie talkie.
    supermaxx123's Avatar
    supermaxx123 is offline CarAudio.com Elite
    Aug 2009
    I.E.
    1,833
    47 Post(s)
    Re: Suggestions for 8"-10" Midwoofer
    is your transmission line tuned to the e8's? because the sa8 have a different fs.
    Bought from: tc3k101, vitveet, chico305, pieper88, Toxic Tuan, rusty_armadillo, tristanmay
    Traded with: modskwod, jmkanek
    Sold to: smd4life, AQHDC3, fastfocus00
    got_focus?'s Avatar
    Feb 2007
    Loveland, CO
    36
    1,549
    New box will be built
    2009 Nissan Sentra
    perfecxionX's Avatar
    perfecxionX is offline CarAudio.com Veteran
    Dec 2006
    indianapolis
    2,566
    41 Post(s)
    A lot of people have said good things about these:
    Parts-Express.com:Peerless 830869 8" Nomex Cone HDS Woofer | Peerless P830869 830869 8" midwoofer HDS Woofer nomex cone sandwich woofer bass mid midbass mtm 2-way vline logic line array tymphany09
    Doesn't look like you'd want to cross them much over 2k though
    Actually since you have a dqxs, you might consider doing 4 way. Get an 8" peerless sls, and find a good 3 or 4" midrange.
    http://www.parts-express.com/pe/show...umber=264-1102
    “Ignorance more frequently begets confidence than does knowledge" Charles Darwin
    refs---
    http://www.caraudio.com/forum/showthread.php?t=219529&highlight=perfecxionx
    http://www.caraudio.com/forum/showthread.php?t=259748
    http://www.diymobileaudio.com/forum/itrader.php?u=28091
    http://www.caraudioclassifieds.org/forum/itrader.php?u=916
    http://myworld.ebay.com/perfecxionx/
    got_focus?'s Avatar
    Feb 2007
    Loveland, CO
    36
    1,549
    Looking to stick to a 2 way setup.
    2009 Nissan Sentra
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    No driver linked in this thread will deliver "amazing midbass" or even being to keep up with a set of horns. Even if we give the horns 1 watt of power those 10's aren't going to keep up going full bore.... You need a high effeciency mid. Look at your effeciency spec and shoot for 94db/1w/1m at least. Xmax isn't a big deal since 10's have alot more cone area than a 6.5 or an 8. Just 4mm will get you down to 80hz with a steep slope.
    Anyway if your budget is around the morel of 140ish per speaker
    B&C 10NDL64
    or Faitel Pro 10PR300
    The B&C is probably a little nicer, it also cost a bit more. Both are neo which will keep the back end size down, which help since your trying to cram a pro audio 10 into a door....
    Quote Originally Posted by sdmtnbiker420 View Post
    JL is for ballers. Theres a reason all the biggest rappers sing about JL, Zapco, Alpine..... and not Lightning audio or Pyle. It's all about the BALLER FACTOR.
    got_focus?'s Avatar
    Feb 2007
    Loveland, CO
    36
    1,549
    Budget is $500/pr
    Also, I have about 8" of depth to work with.
    2009 Nissan Sentra
    Horsemanwill's Avatar
    Horsemanwill is offline CarAudio.com Veteran
    Aug 2008
    Junction City, Kansas
    2,975
    27 Post(s)
    if i may recommend how about the ID X69 mid has a lil more cone area then an 8 and has NO problem keeping up with horns
    Pioneer Carrozzeria DEH P01
    Tru SB6
    Silver Flute W17RC38-08 6-1/2" Wool Cone
    Tru Steel S25
    ES Full body horns soon to come
    2x JBL W12GTI
  9. #9
    T3mpest's Avatar
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    Quote Originally Posted by got_focus? View Post
    Budget is $500/pr
    I'd go with the B&C's then. Very nice drivers and they will defintely fit as they are about 4.5" deep IIRC.
  10. #10
    James Bang's Avatar
    James Bang is offline Hand/Ear Coordination
    Aug 2005
    34
    13,018
    Budget is $500/pr
    wowzers.
  11. #11
    got_focus?'s Avatar
    Feb 2007
    Loveland, CO
    36
    1,549
    Quote Originally Posted by Horsemanwill View Post
    How would you compare the x69 to the x65?
    2009 Nissan Sentra
  12. #12
    got_focus?'s Avatar
    Feb 2007
    Loveland, CO
    36
    1,549
    Quote Originally Posted by James Bang View Post
    wowzers.
    Fiberglassed door pods
    2009 Nissan Sentra
  13. #13
    got_focus?'s Avatar
    Feb 2007
    Loveland, CO
    36
    1,549
    Any other suggestions?
    2009 Nissan Sentra
  14. #14
    Aug 2008
    2,975
    27 Post(s)
    the x69 has more cone area so it has a greater output.
    Tru SB6
    Tru Steel S25
    2x JBL W12GTI
