Results 1 to 6 of 6
Reload Thread: Polk db series
    tommybrown's Avatar
    tommybrown is offline Member
    Dec 2009
    Los Angeles
    31
    Polk db series
    I had these awful Infinity reference speakers with super harsh highs. I took those out and replaced them with the polk db series 6 1/2' component system in the front and 6x9's in the rear. These sound a lot better but for some reason I"m not completely sold on them. To me they seem to be missing some crispness or sharpness that other speakers have. I've tried adjusting my JL audio 4-channel amp but it didn't change this at all. Any thoughts on this?
    misfit138's Avatar
    misfit138 is offline a whole new type of aids
    Jun 2009
    Williamson, WV
    12,048
    2 Post(s)
    Re: Polk db series
    Are your doors deadened & sealed?
    I shot out muh mom's vag with bossing papers in hand.
    tommybrown's Avatar
    Dec 2009
    Los Angeles
    31
    Re: Polk db series
    I believe so. The speakers aren't visible since they were installed underneath the door panels just like the factory speakers were. The tweeters are installed underneath the grills on the dash.
    misfit138's Avatar
    Jun 2009
    Williamson, WV
    12,048
    2 Post(s)
    Re: Polk db series
    How can you not know if your doors are deadened & sealed? Did the installer (I'm assuming you didn't install them) apply sound deadening material or not?
    tommybrown's Avatar
    Dec 2009
    Los Angeles
    31
    Re: Polk db series
    No there was not sound deadening material installed.
    misfit138's Avatar
    Jun 2009
    Williamson, WV
    12,048
    2 Post(s)
    Re: Polk db series
    Quote Originally Posted by tommybrown View Post
    That's a problem. Deadening and sealing the doors will greatly increase your midbass. Mounting the tweeters in a better location will help with imaging too. And if I'm not mistaken, you can change the db level of the tweeters on the crossover.
    You have some work to do.
    Here's some deadener: http://www.secondskinaudio.com/produ...hp?category=70
    Here's a tutorial on how to get the job done: http://www.caraudio.com/forum/speake...ening-you.html
    Search google for a tutorial on stereo imaging/sound stage...
