Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Reload Thread: Which SEAS textile or aluminum?
    srtmat's Avatar
    srtmat is offline Junior Member
    Mar 2009
    Wausau WI
    I'm looking to replace the tweets from my PG RSD 6.5's. One sounds like it's shot. I think I've narrowed it down to the SEAS but I'm not sure which one is best.
    I'm running passive off the stock PG crossover with about 100 watts. Tweeters are located in the sail panels. Both sets say they play down to 2500 hz but I can't find any good hard data on the crossover point on the PG crossover I think I heard 2700 hz.
    I don't think I can go wrong with either. I'm just looking for something smooth not to bright.
    Any input or other suggestions would be great.
    thanks
    Mat O
    Rich B's Avatar
    Rich B is offline CarAudio.com Veteran
    Oct 2006
    *under the rainbow*
    6,504
    14
    235 Post(s)
    Re: Which SEAS textile or aluminum?
    If the tweeters are close to your ears I've found its best to go with a soft dome.
    Metal domes tend to be brighter, which works best mounted low in the doors or kick panels.
    SSS 18734's Avatar
    SSS 18734 is offline Dollar Menu Millionaire
    Mar 2005
    Kansas City, MO
    5,457
    3 Post(s)
    I really doubt you would hear much, if any, difference between the two. They are essentially the same tweeter.
    I've heard that the Neo Alum is actually rather laid back for a metal dome tweeter.
    Bought From:
    Absolutnockout, zachzchw, Untouchable11, j3bus2k3 (x2), 92c1v1c, jeeper07, acubsfan, bkjt05, Goldenknob, Goindef154, Basscourt2009, TeamSouthrnBass, oldschoolboomer, 99grandprixGT
    Sold to:
    Gearguy2001 (American Bass SQ780)
    Tw1st3d13 (2 Fi BL 15's)
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Quote Originally Posted by SSS 18734 View Post
    They are not bright like a normal metal dome can be. Alum domes would be a good choice for what you plan to do.
    srtmat's Avatar
    Mar 2009
    Wausau WI
    Wow thanks for the quick response guys!
    I think I might give the metal domes a try.
    Do any of you have an idea on the PG crossover point?
    mlstrass's Avatar
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Quote Originally Posted by srtmat View Post
    no, but I installed a pair of the Sea's last year for a guy as replacements for the blown tweeters in his RSD set and they sounded fine.
    RowJoe's Avatar
    RowJoe is offline Counting hallways...
    May 2008
    Las Cruces, NM
    569
    Those Seas tweets are going to be very accurate. Bad recordings will sound bad. Some people recommend using a xover point of around 5Khz or so for these guys.
    srtmat's Avatar
    Mar 2009
    Wausau WI
    I am running this system off a IDA-305 ipod only head unit. Needless to say a lot of my music is only 128 bit recordings. Not the greatest sound quality. Maybe I should look elsewhere?
    Mat
  9. #9
    okiedokie's Avatar
    okiedokie is offline CarAudio.com Elite
    Aug 2008
    Pleasant Hill, CA
    94
    1,356
    13 Post(s)
    ^^^The seas will work good, just call PG up & ask them what are the xover pionts for that passive xover.
    I had the Seas & yes they do say you can cross them over that low but becareful ,mine didnt like it that low.
    If you're to be going raw driver, maybe you should look at a large format tweeter?
    if you blow the vioce on a large format tweeter you'll be able to replace the voice coil. verse if you buy from Madisound & Partsexpress small compact tweeters & you blow one you're just stuck with that blown tweeters.
    Once you get use to a large format tweeter you'll never want to go back to compact tweeters
    http://www.madisound.com/catalog/pro...oducts_id=8646
    http://www.madisound.com/catalog/pro...oducts_id=8647
  10. #10
    2NYCE's Avatar
    2NYCE is offline post while drift
    Jun 2009
    Gotham City, NY
    627
    I have the seas alums playing with my pg mids
    I crossed them at 3.2khz
    They are very detailed tweets!
    BTW....I had to do some fine tuning to eliminate the brightness (tweets are above the dash). Not as bad as the other metal tweeters Ive listened to.
  11. #11
    okiedokie's Avatar
    Aug 2008
    Pleasant Hill, CA
    94
    1,356
    13 Post(s)
    yes dont go below 3.kz
  12. #12
    okiedokie's Avatar
    Aug 2008
    Pleasant Hill, CA
    94
    1,356
    13 Post(s)
    khz
  13. #13
    2NYCE's Avatar
    Jun 2009
    Gotham City, NY
    627
    they play ok down to 2.5khz (w/ steep slope)
    but to me it sounds better over 3khz
    they do pick up the bad recordings lol
  14. #14
    denim's Avatar
    denim is offline SSAudio.com
    Oct 2002
    SSA HQ East
    40
    29,103
    15
    66 Post(s)
    911 Post(s)
    The SEAS textile tweets matched up really well with the MLI-65's for me in a recent install.
    CarAudio.com mod(original)
  15. #15
    2NYCE's Avatar
    Jun 2009
    Gotham City, NY
    627
    Quote Originally Posted by denim View Post
    those Mach5 mids are nice
    when I get tired of the PGs I will pick them up again lol
