Results 1 to 4 of 4
Reload Thread: head unit watts un used
    zoolander's Avatar
    zoolander is offline Junior Member
    Jun 2009
    oregon
    im using a crunch 4 channel amp 900 watts to run 4 6x8's in my 2002 f250.
    my question is, can i use the watts from the head unit to run some tweeters? the head unit i have is Pioneer AVIC-F900BT \RB. i dont think it will work because the RCA's are ran to the amp.
    revrider1's Avatar
    revrider1 is offline Hmmm...
    Jul 2005
    Down South~3rd Coast~TX
    33
    29,597
    Re: head unit watts un used
    Hmm
    BeAlLsTaR13's Avatar
    BeAlLsTaR13 is offline CarAudio.com Veteran
    Mar 2009
    New York
    2,615
    1 Post(s)
    if you ran power from your HU to tweeters you'd need a crossover else it will sound like crap
    New build in progress...
    Nov 2008
    ct
    109
    Quote Originally Posted by BeAlLsTaR13 View Post
    Yep, plus you'll destroy them without a crossover as it will send bass signals to them as well as highs. Of course a cheap crossover can be made by hand using easy to buy parts.
    However.....
    Typically head units generally produce less line level output signal if the internal amp is being used to drive speakers off of it.
    To top it all off, your deck will distort before your line out will, which means you'll need to further reduce your max dynamic range by running at a lower deck volume (and forcing a higher amp input gain) in order to not clip the tweeters, even though the rest of the system would be chugging along ok. So now your let's say 4v rca output might really only be able to be used at say 500mv.
