Results 1 to 6 of 6
Reload Thread: any1 know wat sup with the sound coming out of tweater when engine turn on
    mdd99's Avatar
    mdd99 is offline Member
    Jun 2003
    Los Angeles, CA
    28
    132
    it get louder when step on gas peddal...need help to get rid of the soudn.
    Bavarian3's Avatar
    Bavarian3 is offline Ownz joo
    Mar 2003
    Nor*Cal
    26
    5,170
    Re: any1 know wat sup with the sound coming out of tweater when engine turn on
    comin out of the tweeter? are u sure. Otherwise, it would be a alternator whine. U should run urs RCA's through the middle of the car.
    Upcoming SQ competition ready install...
    -Eclipse cd8053
    -Image Dynamics Cd1Pro MH
    -Image Dynamics 6.5" mids with CX motors and poly cone in custom fiberglass kick panels
    -12" Stereo Integrity Magnum in large sealed fiberglass wheel well enclosure.
    -Viper d1200.1 (sub), Viper 400.2 (mids), David Navone Amp-100 (horns)
    bri487's Avatar
    bri487 is offline Banned
    Feb 2003
    birth canal
    7,439
    are your power cables ran with your rca's? that is the most common cause of engine noise. if not, i know that some of the newer amps, such as xtant have a switch on them that is designed to be used with newer engines. all i had to do with my boat to get rid of the engine noise was flip a switch on the amp.
    evilsaint's Avatar
    evilsaint is offline CarAudio.com Elite
    Sep 2002
    NW Chicago 'Burbs
    29
    999
    3 Post(s)
    Check to make sure none of your speaker wires are touching any metal part of your car, check to make sure all your grounds are solid, and like bri said, run your rcas on the other side of the car from your power wires if possible.
    The term for this kinda noise is "ground loop", if you want to do a search on it.
    2002 Mercedes-Benz C32 AMG - Stock Bose stereo ... but 13.2 in the 1/4 mile!
    RIP Darkie : 96' Bonneville SSEi
    Alpine 7998
    PPI A404.2 Art Series -> Focal PolyKevlar 136K's Front
    1700WRMS -> RE SX 12" in 2.0Cf ported to 35Hz (Big props to IonSQL for my BEE-YOO-TIH-FUL box!)
    Refs - M@nJo, Mebcop, IonSQL, NJTStang11, XXXBassHead, Havieri23, SQStephen
    pioneer's Avatar
    pioneer is offline CarAudio.com Elite
    Mar 2002
    Trinidad & Tobago
    30
    741
    Hey this same thing happens to be, it started when i put a blass blocker down by the kick panels, it now occured to me that it could be touching the car body. All the other connections are good. Power and RCA's are seperate. I'll tell you guys how it works out by tomorrow
    why run with the crowd ?
    http://www.steveselectronics.biz - join the forum
    crhye250r's Avatar
    crhye250r is offline Installer
    Oct 2002
    Clay, KY
    28
    985
    Two most common causes of engine whine..
    1. Run power and RCA separate.
    2. Check all your grounds. Put sub amp and high amp ground as close together as possible, if not together.. cuts down on ground loop.
    MECP Certified Installer
