Results 1 to 8 of 8
Reload Thread: Crossover Question
    kcollazo86's Avatar
    kcollazo86 is offline Junior Member
    Mar 2009
    Jersey
    15
    Icon32 Crossover Question
    Hello I have a question i wanted to get a better sound for my Highs and Mids and wanted to know what Crossovers or maybe even bass blockers i can use to better my sounds my voice setup is
    2 10" Ev DL10X the impedance is 8 ohms 100-2000 hz
    2 6.5" beymas 6mi90 the impedance is 8 ohms and the freq 150hz- 8.0khz
    i dont remeber what kind of tweeters but there 4" dome titanium bullet tweeters there 8 ohms
    The amp i have runing to this is a SoundStream TRX 4.880
    hopefully somone can lead me in the right direction
    pjhabit's Avatar
    pjhabit is offline Senior VIP Member
    Aug 2008
    wrong side of the tracks
    323
    Re: Crossover Question
    Your amp has adjustable crossovers built-in (HPF 50Hz-500Hz & LPF 50Hz-150Hz).
    Are you talking about a passive x/o for the mids & tweets?
    //Alpine 9887
    CDT BCK-26A tweets
    CDT ES-6 mids
    JL 450/4v2
    JL 500/1v2
    JL 12W6v2
    kcollazo86's Avatar
    Mar 2009
    Jersey
    15
    Yeah I knew I had a crossovers on the amp. Just thought I could clear my voice alittle more... is there anything I can do to get a better and maybe little more louder voice out of my speakers each speaker is ran to there own channel... but they had told me to run everything and bridge it and run it al to one channel and just get bass blockers for the speakers but tha sounds alittle nuts to me...
    Litunerkid's Avatar
    Litunerkid is offline Member
    Apr 2009
    LI,Ny
    147
    being that that beyma play up fairly high you can find a crossover with a higher high pass filter. 5 k or so woud be fine.check out partsexpress.com and look at the dayton 3 way crossovers.
    refs- Millertime1028, DJL, SlappnCentury,MECHMAN
    07BronzeFuz's Avatar
    07BronzeFuz is offline DueceEDuece
    Mar 2009
    Nashville North Carolina
    430
    can you adjust the slope on it from 0 to 180? Would that help
    ***Feedback***
    Sold To: dbass
    Bought From: FLVarsity, chaunb3400
    EBAY: chadr02 89 items 100%
    Email: jackedonthejuice@embarqmail.com
    2007 Ford Fusion SE
    2.3l 5 speed
    Alpine cda-9855
    ED Nine.4
    Ed Nine.2x
    2 12" Powerbase Evolution D4
    kcollazo86's Avatar
    Mar 2009
    Jersey
    15
    yes if im not mistaking i can mess with the slope... but what if i get a Equalizer would that help me on my system more to get a better sounds or its not worth it ? would like to get the opinion on somone before i jump into something thanks guys
    pjhabit's Avatar
    Aug 2008
    323
    Quote Originally Posted by kcollazo86 View Post
    So you're powering each speaker independently on its own channel, resulting in the full range of frequencies being produced by each speaker...correct?
    If so you'll need a HU, amp or external processor w/ active crossover capabilities to filter out the frequencies the drivers don't like. I would'nt recommend it to a novice w/o a good understanding of crossovers/slopes & phase relationships.
    Or you can get a passive crossover & take an educated guess @ what x/o points will work best. It would kinda be a shot in the dark, but then you could bridge the amp & send each channel to the passive x/o which will then split the frequencies between the front speakers accordingly.
    I think your best bet would be to sell the fronts & pickup a new set of components. Bridge the amp & use the passive crossover that is supplied/designed for the comps.
    Quote Originally Posted by 07BronzeFuz View Post
    No. I think you're referring to phase
    //Alpine 9887
    CDT BCK-26A tweets
    CDT ES-6 mids
    JL 450/4v2
    JL 500/1v2
    JL 12W6v2
    kcollazo86's Avatar
    Mar 2009
    Jersey
    15
    Quote Originally Posted by pjhabit View Post
    Thanks this helps alot .. Do you guys think getting a eq will do me any good if so which. One is a good one ? ThAnks
