Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Reload Thread: 09 CDTs question with amp
    Magnatus's Avatar
    Magnatus is offline Banned
    Sep 2006
    AZ
    341
    11 Post(s)
    going with
    http://vertexaudio.com/store/pc/CDT-...t-Set-30p7.htm
    and i am getting a free visiontek v4208 150RMSx4 channel susposly, for free from my father in law so would these speakers be a great match since their 150rms?
    Does that include tweeters being 150rms or just the 6.5's?
    terra's Avatar
    terra is offline CarAudio.com Veteran
    Feb 2005
    Yes
    7,479
    76 Post(s)
    Re: 09 CDTs question with amp
    Great place to buy them.
    That means the set is 150 rms. The power is distributed by the crossover.
    Magnatus's Avatar
    Sep 2006
    AZ
    341
    11 Post(s)
    Ohhh i see so if that amp is 150rms X 4
    then isnt the amp way too powerfull?
    terra's Avatar
    Feb 2005
    Yes
    7,479
    76 Post(s)
    You can use the front 2 channels on the 2 speaker sets. Or bridge the amp and run 150-180 watts on em.
    Magnatus's Avatar
    Sep 2006
    AZ
    341
    11 Post(s)
    **** im a noob so kinda that makes some sense
    if i have a Audioque 1200D for my tc9 subwoofer and have this other amp hooked up to same battery will that make me dimm more likely than just the AQ? i can see two subwoofer amps to same battery making it very bad but a speaker amp and a subamp doesnt seem so bad to me with big 3 mod,
    terra's Avatar
    Feb 2005
    Yes
    7,479
    76 Post(s)
    Adding another 300 watts shouldn't hurt you much.
    Magnatus's Avatar
    Sep 2006
    AZ
    341
    11 Post(s)
    gotcha so basicaly bridging the amp (4) channel amp reduces the channel in half which makes it 2 channels of 150RMS each
    your sayign 1 channel going to my two 6.5's which split 150rms
    and the other channel goes to my two tweeters which split 150rms
    is that the basic idea or im i not even close
    thank u for ur help by the way i apreciate it
    terra's Avatar
    Feb 2005
    Yes
    7,479
    76 Post(s)
    Quote Originally Posted by Magnatus View Post
    If the amp is able to bridge its channels, yes it will combine the channels. But it should put out closer to 500 watts per channel then. Have to set the gains accordingly.
    No the tweeter and mid are connected to the crossover. You send the power to your crossover which divides the power between mid and tweeter.
  9. #9
    Magnatus's Avatar
    Sep 2006
    AZ
    341
    11 Post(s)
    Quote Originally Posted by terra View Post
    should i tell me friend to just bridge it when he hooks it up and keep gains all the way down on everything?
  10. #10
    terra's Avatar
    Feb 2005
    Yes
    7,479
    76 Post(s)
    Ya bridge it and set the gains with a dmm
  11. #11
    Magnatus's Avatar
    Sep 2006
    AZ
    341
    11 Post(s)
    DMM?
    and my friend said theirs these splicer things that go on your battery a seperate wire from battery to Speaker amp and another splicer wire from battery to Sub amp is that correct?
  12. #12
    terra's Avatar
    Feb 2005
    Yes
    7,479
    76 Post(s)
    It doesn't matter. Both amps need to be connected to the battery somehow. You shouldn't be splicing anything.
    DMM=Digital Multimeter. Very needed tool.
  13. #13
    Magnatus's Avatar
    Sep 2006
    AZ
    341
    11 Post(s)
    how much are they
  14. #14
    terra's Avatar
    Feb 2005
    Yes
    7,479
    76 Post(s)
    Anywhere from $1.99 to $199.
    Does your amp do 150x4 at 4 ohm or 2 ohm?
  15. #15
    Magnatus's Avatar
    Sep 2006
    AZ
    341
    11 Post(s)
    those are actual specs, alot more then 150 =/
    u sure it will still work and not blow my new speakers if i have gains all the way down =[
    RMS Power at 4 Ohms 250 W x 4
    RMS Power at 2 Ohms 360 W x 4
