Results 1 to 14 of 14
Reload Thread: Door panel mounted mids,Proper Sound Deadening tips?
    CJL's Avatar
    CJL
    CJL is online now CarAudio.com Veteran
    Mar 2006
    oZone
    3,792
    I know how to properly deaden doors which the mids screw directly into,.. MDF baffle,non Hardening clay,sound deadener inside /outside door, but what about speakers that mount to the door panel such in Chrysler vehicles?
    How can you get the best midbass(SQ) results when the speakers mount in the door panel?
    REFS:
    eatank,mikescanlon,BoominBeast,Pistonsfan70,90accordman,bizflawless,Mazdakid,Boyle465,LiquidClen,dman4486,
    KickerSoItBump, SPY,1000101,infamous_e46
    Bought-Sold-Traded
    headless's Avatar
    headless is offline CarAudio.com Elite
    Feb 2006
    Florida (Tallahassee)
    1,293
    Re: Door panel mounted mids,Proper Sound Deadening tips?
    Replace the door panel with a new fiberglass doorpanel
    Eclipse CD7000 - RioCar Empeg 3
    Rainbow Powerline CS 275.27 / Arc Audio 4150 XXK (Woofers) - Arc Audio 2100 XXK (Tweeters)
    Rainbow Vanadium 12 x2 / Arc Audio 1500 XXK
    Quote Originally Posted by TEAM HAMMER
    Your so full of Crap! The last place you want a Midbass or Sub is in front of you Retard Whens the last time you seen a 12in+ sub up front?
    Quote Originally Posted by bdawson72
    Technically, bigger wire has more resistance.
    CJL's Avatar
    CJL
    Mar 2006
    oZone
    3,792
    Dont think I wann get that custom with it. Trying to keep it practical.
    REFS:
    Bought-Sold-Traded
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    Same way in some of the audi's. To improve midbass in the one I worked on. I made a neoprene gasket that went around the entire perimeter of the door panel. Once the door panel was put back on it created a nice seal. Improved the midbass a lot
    5 % equipment
    90 % install
    5% beer
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    31
    13,134
    8 Post(s)
    any pics or more details?
    www.BassHeadsENT.net for all your custom enclosure needs
    Offering build service and expertise in the Tampa area as well as enclosures shipped nationwide!
    Robin@BassHeadsENT.net
    Check this thread for all the build logs being posted.
    http://www.caraudio.com/forums/suppo...ks-thread.html
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    Quote Originally Posted by iamamp3pimp View Post
    WHo me ?
    5 % equipment
    90 % install
    5% beer
    Nov 2003
    Tampa FL
    31
    13,134
    8 Post(s)
    yes sip!
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,691
    He kidnapped Gumby and Pokey and used them to reinforce his baffles
  9. #9
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    Don't think there are any pics of it. I just took some strips of neoprene about and inch wide. Sprayed them down with glue, and folded it in half. Then glue this to the back side of the door panel around the perimeter. The A6 had a nice little lip in the back of the panel already. Took a little elbow grease to get the door panel back on. But the improvements were worth it. It works two fold, it seals the door up better than what it was, and it also breaks the physical contact of the plastic panel on the metal door alleviating a lot of the buzzes.
    5 % equipment
    90 % install
    5% beer
  10. #10
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    Quote Originally Posted by JimJ View Post
    My mids mount to the doors..................somewhere under the 20 lbs of clay lol . Webstars Audi had the midbasses mounted on the door panels
    5 % equipment
    90 % install
    5% beer
  11. #11
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    Lead sheeting can be your friend in this situation as well
    5 % equipment
    90 % install
    5% beer
  12. #12
    CJL's Avatar
    CJL
    Mar 2006
    oZone
    3,792
    Heres a couple pics of my door i took today. More thoughts welcome.
    REFS:
    Bought-Sold-Traded
  13. #13
    FoxPro5's Avatar
    FoxPro5 is offline Causal wanderer
    Aug 2005
    3 octaves higher
    5,450
    Which driver?
    My thought is those rain guard things choke the driver and change it's Q in a bad way. Do you like the sound with them in? Have you tried without?
    I'd go through and glue the panel together, hence making it one more solid piece. From there, you can damp with squares of deadening mat it where it resonates. Test it by whacking it with the butt end of a screw driver.
    Not a fan of creating a floating baffle by decoupling the panel from the door in this case. Let a VE damper do it's job and treat rattles at the source.
    Deadening is not mass loading. Heavier things are more difficult to set into motion, sure..but use weighting things down as a tactic once a VE damper has been given a chance to do that for you. I have lots of lead and clay and other stuff in my doors too, but a little more planning and thought process could have saved me 10# and possibly my poor hinges down the road.
    TEAM Front Fill
    The Fox audiomobile now sounds more quality thanks to SDS power.
    The most expensive solution is the one that doesn't do the job correctly. ~ Me
  14. #14
    CJL's Avatar
    CJL
    Mar 2006
    oZone
    3,792
    Quote Originally Posted by FoxPro5 View Post
    Which driver?
    That is a stock speaker,and not sure what i plan on running. It sounds ok as is,just some buzzing/ rattles.
    I havent took the panel off in a while but IIRC, there isn't a access hole for the speaker to breath inside the door. Just sheet metal behind it.
    REFS:
    Bought-Sold-Traded
