Results 1 to 11 of 11
Reload Thread: my 6x9s are clipping
    BLACK12's Avatar
    BLACK12 is offline Junior Member
    Sep 2003
    WILLINGBORO NJ
    my 6x9s are clipping when i turn my system up. they are jbl 350 watts each. im looking for new ones but dont know what to look for. should i go for speakers with more watts?or just better quality speakers. i was looking at these 4 way 1400 watt 6x9s but im not sure.what do u think?
    mattj's Avatar
    mattj is offline Resonant Engineering
    Aug 2002
    Wisconsin
    34
    6,293
    Re: my 6x9s are clipping
    you gains are set too high if they are clipping...
    (SUMMER)
    2001 Ford Mustang GT Premium
    Mach460
    Alpine CDA-9835
    KnuKonceptz Wiring
    DARKHART's Avatar
    DARKHART is offline One Hitter Quitter
    Aug 2002
    LITTLE ROCK, AR
    2,288
    196 Post(s)
    Quote Originally Posted by BLACK12
    How is your system set up? Are you amping your 6x9's or are you running them off your headunit. If you have an amp on them, what is the rms rating of the amp and the rms rating of your 6x9. JBL makes so pretty good 6x9's that can had some decent power. What do you have....we need more info to properly answer your question.......
    Just when they though it couldn't get any worse, in came the Lord of Kaos, the Darkhart has arisen from his century long slumber..
    ____________
    refs:
    Type-S Texan ............Xtremebass5
    NE14MX ........Grinder1989
    NJack2AF
    .............Jameseypoo
    Randyrsx ..........Bagdntagd
    M3Transporter......Teggybwoy
    RJ Sclafani...........Zeuslicious
    Saltyreefguy........Qkassidyw
    Qtrhorse..............Nismos14
    Pistonsfan70........4nine
    SlainNothing.........Orangelss
    [email protected]............Louisiana_CRX
    SW9152..............DukeNut
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    36
    8,477
    32
    LOL @ 1400 watt 6x9s
    But yeah...answer the aforementioned questions and we can help ya out.
    "The world is full of people who want nothing short of perfect,
    but settle for less, blinded by their quest for purpose."
    - Slug
    mattj's Avatar
    Aug 2002
    Wisconsin
    34
    6,293
    is that legacy, pyramid, road gear 1400 watts or TRUE 1400w RMS
    (SUMMER)
    Mach460
    Alpine CDA-9835
    KnuKonceptz Wiring
    S-B 4Life's Avatar
    S-B 4Life is offline Member
    Sep 2003
    Michigan
    30
    30
    I have JBL 6x9's GTO series 100 watt rms 300 watt max powered with a profile 100 rms x 2 at 4 ohms and i have my gains a little lower then half and no bass boost running off the amp i just use the X-Bass off my headunit and they sound good so if there clipping you have your gains to high off ur amp or the bass boost is on and if ur running off HU then you might have a wiring problem.
    DARKHART's Avatar
    Aug 2002
    LITTLE ROCK, AR
    2,288
    196 Post(s)
    Quote Originally Posted by S-B 4Life
    I'm really not understanding the last half of your statement, it almost sounds as if you are anwserring your own question. Try turning your gains all the way down and when you use your x-bass on the headunit now see how it sounds, also what is the bass cut off freq set at on your amp, because you 6x9's really aren't made to drop bass at the same level as a set of subs...
    ____________
    refs:
    NJack2AF
    S-B 4Life's Avatar
    Sep 2003
    Michigan
    30
    30
    ......... I know they dont but mine do :] naw but i dont set my gains high because i want that extra room to turn the x-bass on because i really rather have SPL then SQ
  9. #9
    namster44's Avatar
    namster44 is offline Great White North
    May 2002
    Canada
    646
    grab yourself some comps, 6x9's are nice at low volumes, but distort like crazy once some power is thrown at them
    This years line up.....
    *eD, Tsunami, CDT, Alpine, EFX wiring/block/fuses*
  10. #10
    S-B 4Life's Avatar
    Sep 2003
    Michigan
    30
    30
    True story....... but my HD goes up to 100 volume i can put it at about 55-57 with 2/4 x-bass but not much after they they crumble :P
  11. #11
    lexiphanic's Avatar
    lexiphanic is offline eD rocks :)
    Jul 2003
    Mankato, MN
    85
    If you have a sub, set them to about 100hz and let your sub grab the rest. It will move the soundstage, but if your soundstage sound like crap otherwise, you could probably live with it.
  1. Replies: 10
    Last Post: 12-21-2003, 01:39 AM
  2. JBL 935e 6X9s
    By wjohnson12321 in forum Speakers
    Last Post: 09-09-2003, 07:15 AM
  3. 6x9's clipping
    By adr531 in forum Speakers
    Last Post: 09-02-2003, 12:33 AM
  4. Half decent inexpensive 6x9's
    By Silica in forum Speakers
    Last Post: 08-06-2003, 01:03 PM
