Results 1 to 4 of 4
Reload Thread: 5.25" in place of 4x6
    Mar 2009
    Franklin, WI
    64
    I got a 2002 cavalier and im looking to replace the front speakers with 5.25" components and a 2 channel amp. I can make a mounting ring for them but does anybody have any experience with doing this kind of thing?
    Help is definitely appreciated. Thanks
    2002 Chevrolet Cavalier
    Headunit - Pioneer DEHP3000IB
    Front Stage- TS-D720C (Currently powered by PDX2.150)
    Rear Fill - Infinity Kappa 6x9 3 Ways
    RCAs - Kicker S-Series
    Power Wire - Monster Wire 1/0 Gauge
    Kicker 12" L7 in a Sealed Box
    Rockford Fosgate T10001bd
    Now I need deadener
    Bought From: SoCalBean420, DUMPED, Smaxor5, wgsj_fortvalley, BushJ311
    Alex JB's Avatar
    Alex JB is offline Senior VIP Member
    Oct 2008
    Chicago IL
    212
    Re: 5.25" in place of 4x6
    Can you still fit your trim pannel if you have a mount ring and a 5.25?
    If so, just go for it, check your mounting depth is always a good idea first
    JL 6.5's in the front doors
    AP1040 bridged driving them.
    2 Sundown E8's in 1.1cu ft tuned to 30Hz.
    700rms @ 2Ohm Cadence... let's see what the the E8's can take
    fasfocus00's Avatar
    fasfocus00 is offline doITdaWHITEwayORdoITtwice
    Jun 2007
    New Orleans, LA
    4,974
    4 Post(s)
    it's relatively easy to make. take out the stock 4x6, trace the outside to a piece of carboard. than take a grill from the 5 1/4 you plan on using and put it onto the outline you previously made. move it so that the inside diameter of the grill is inside of the outline. trace the inside and outside of the grill and BAM!! you now have a cardboard template. make sure you have atleast 3/4in of spce from the inside of the ring to the outside. you can even take the carboard template to the current speaker location and make adjustments as needed to make it fit properly.
    Here is my feedback Thread: http://www.caraudio.com/forum/showth...ght=fasfocus00
    "If you ain't cheatin', You ain't trying"
    th3disturbed1's Avatar
    th3disturbed1 is offline Member
    Mar 2009
    Franklin, WI
    64
    any ideas on what speakers would be good to use? i dont think my alternator can take any more power added to it so scratch the amp idea. any speakers you would recommend for about a $100?
    Now I need deadener
