Results 1 to 6 of 6
Reload Thread: Are these the same????
    2 Guard's Avatar
    2 Guard is offline Member
    May 2007
    P.H.X AZ.
    81
    5 Post(s)
    Icon7 Are these the same????
    I finally got a chance to listen to the Morel Dotech Ovation comp 6 an i like them for my new setup. As i'm serching around i also found the Phoenix Gold Ti6 Comp Elite. They look to be the same mid-driver, not sure on the tweeter though.
    Does anyone what the difference is between the 2??? Is the sound between the Morel and the PG the same?? or close enough to were 1 might not know the difference.
    Thankx for the info.
    Oct 2007
    Queens, NY
    26
    7,385
    149 Post(s)
    Re: Are these the same????
    morel will obviously be better.
    links?
    Refs : nismos14, Slammed x3, Team H&K, RetroAudioInc, 2002XLT, tc3k101, Fusion_Freak, IAmMurph, louisiana_crx, fast85_gt, Ridnclean x3,
    woofercooker, lil_italy773 x2, 1mtx1, flipx99, MSW Danny, the_greatest_penn, jco1385, walksup, darkhunter139, TurdFurgeuson2, jmanpc, explorer2,
    Jep772, 86yota, fargof, brtnboarder3241, Pitbull12887, Spooney, Phers1er,
    edzy's Avatar
    edzy is offline SPL Ninja
    Feb 2007
    Where you live
    2,190
    the pg are Morel made, but the specs are a little difefrent.
    Aslo the tweeters are different. Still both great mids..
    The PG ones..
    Nothing to see here, Move along.
    jmanpc's Avatar
    jmanpc is offline CA.com Nostalgist.
    Jan 2006
    Jacksonville, Fl
    30
    17,265
    Yeah they were made by Morel, and are considered to be a pretty good budget alternative to the actual Morel set.
    2007 Red Ford Focus ZX4 SE
    - Clarion DXZ955MC -
    - MB Quart RSD216 - 2 MB Quart RWE-354 in 4 cubic feet sealed -
    - MB Quart DSC4125 - Audiopipe AP1500.1D - Optima Blue Top -
    Team High Sexage
    edzy's Avatar
    Feb 2007
    Where you live
    2,190
    the PG
    Complete 2-Way component system
    300 watts RMS power handling
    Ultra-thin mounting depth
    3 inch multi-layer voice coil
    Audiophile grade external crossover
    Solid one piece polypropylene cone/dust cap assembly
    FEA optimized inner-radial neodymium motor structure
    Custom cast aluminum basket
    Midrange Sensitivity 89dB (1w/1m)
    28mm hand doped tweeter
    Integrated phase plug for enhanced dispersion
    Crossovers features state of the art computer aided design process for uncompromised fidelity
    Shielded Titanium crossover housing with gold plated speaker connections
    Audiophile components: air core inductors/composite bypassed capacitors
    System includes pair of 6.5" mids, pair of 1" tweeters and professional crossover
    Specifications
    Tweeter Mounting Depth: 1.125"
    Midrange Mounting Depth: 2.2"
    Midrange Mounting Diameter: 5.5 - 6.0"
    Crossover Housing Dimensions: 9.75" X 6.25" X 2.0"
    Frequency Response: 20Hz to 20kHz
    Nominal impedance: 4 Ohms
    Acoustic Crossover Slopes: 24dB per Octave
    SPL: 90.9dB
    The morel
    Nominal Impedance: 4 Ohm
    Power Handling: 160W
    Max. Transient Power Handling: 600W
    Sensitivity (2.83V/1M): 91dB
    Frequency Response: 35-25000Hz
    Crossover Point: 1800Hz
    Voice Coil Diameter
    Woofer: 54mm (2.1")
    Tweeter: 28mm (1 1/8")
    Voice Coil Wire
    Woofer: Hexatech Aluminum
    Tweeter: Hexatech Aluminum
    Magnet System
    Woofer: Hybrid rear vented
    Tweeter: Neodymium
    Mounting Depth
    Woofer: 61mm (2.37")
    Tweeter: 20mm (0.8")
    2 Guard's Avatar
    May 2007
    P.H.X AZ.
    81
    5 Post(s)
    There is only a 50 buck difference between the 2 but that 50 can go to deaden the door's. (Hush-Matt).
