Results 1 to 8 of 8
Reload Thread: What Crossover points for comps & sub?
    sarge_in's Avatar
    sarge_in is offline Member
    Mar 2009
    Orange County, CA
    46
    Hi,
    What crossover points do you suggest for the following in a Honda Odyssey:
    1. Focal 165KR : 60Hz - 20KHz
    2. IDQ10 D2 V3: 5 - 110Hz
    Am running both of them through the Arc Audio KS300.4 amp that puts out:
    RMS @ 4 ohms 4 x 90 watts
    RMS @ 2 ohms 4 x 175 watts
    RMS @ 4 ohms bridged 2 x 350 watts
    I have my gains set at about mid-way.
    The installer initially set the Focals at 110 (I don't have the sub yet). The sound was quite clear but not as warm. I changed to about 80, which made it better for warmth, but i am kinda missing the clarity that I had at 110. So just curious what do others here usually set their crossovers at?
    bamaboy's Avatar
    bamaboy is offline War Eagle!!!
    Oct 2004
    Auburn, Alabama
    29
    7,206
    Re: What Crossover points for comps & sub?
    there is no set point
    mine are set @ 70hz, other people use 100 and 120hz, just a matter of opinion, 110 is just too high for me, just make sure if you do it low that the speakers can handle it
    usually 80hz is a good starting point and go up and down from there if you want to change it
    04 Explorer
    Kenwood DDX812
    RF 3Sixty.2
    T6004
    T4002
    T40001bd
    Hertz MLK-2 running Active
    Hertz HCX165
    4x DC Audio LVL 4 12"s
    Summer 09' Build...Operation:Pull Wall out, put new subs in DONE!
    Build
    Photobucket
    now with video
    KOL's Avatar
    KOL
    KOL is offline Senior VIP Member
    Jan 2009
    my house
    218
    my mids are hp at 80/24db slope & my sub is lp at 65/12db slope
    everyones install, equipment & tastes will vary
    sarge_in's Avatar
    Mar 2009
    Orange County, CA
    46
    thanks for the responses...i agree none of this is a hard rec...depends on tastes, car setup etc. Wud love to hear from more!
    Also, do you setup the HU crossovers (if it has it) same as the amp? Or let the amp be almost full range so you can control just from the HU?
    KOL's Avatar
    KOL
    Jan 2009
    my house
    218
    Quote Originally Posted by sarge_in View Post
    Use one or the other, both together would work but they might affect each other & be unpredictable. The hu is probably the most accurate & it's right at your fingertips.
    Remember overlapping & gaps are perfectly acceptable. In an open cabin like an SUV you might want to lp the sub kinda low & have a gap to keep the bass up front, then use a shallower slope to blend. In a trunk car you might want to lp higher to help the top end fight its way into the cabin, having an overlap of frequencies might blend better in this case. Nothing is set in stone, trial & error is probably the best way to go about it.
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    I have my subs LPed at 63hz with a 24db/oct slope, and the mids HPed at the same frequency and slope.
    2,500+ designs since March 2011
    WOT's Avatar
    WOT
    WOT is offline Banned
    Nov 2007
    Toronto,CANADA
    3,667
    I cross the sub @ 63, 12db slope. Mids @ 80 with 24db slope and 8.5khz top end cutoff @ 6db slope
    probmxstyle's Avatar
    probmxstyle is offline The Well Dressed OG
    Jan 2003
    MD
    32
    1,280
    Sub @ 63Hz w/25 db slope, Mids 63Hz w/ 18Hz slope
    H/U: Pioneer Z1
    Front stage: Polk SR6500
    Front stage amp: Kicker SX500.2
    Acc: Kicker SXRC network controller
    Subs: MTX 9512-44
    Sub Amp:MTX TE1501D
    Battery: Optima yellow top
    Sound Dampening: Dynamat extreme
    Refs: LopezEL, PatFitz9, iamamp3pimp, nismos14, ctcsoft, negativezeroz, BigOso, LegendaryLemon, Pickler,86svo, chrisw91,gixxer9
