Results 1 to 5 of 5
Reload Thread: how to make componets
    99concorde's Avatar
    99concorde is offline laughing at you
    May 2003
    naptown
    31
    196
    i just purchased a pair of re 8s i want to use for componets. what tweeters would u recommend. i want titanium i think. also where can i get crossovers for them.
    lost
    b0mbrman's Avatar
    b0mbrman is offline il Don Baglione
    Feb 2003
    233
    Re: how to make componets
    Since they're subwoofers, they probably don't have much in the way of midrange (especially if you're mounting them in the doors) so expect to cross the tweeters very low.
    I'd recommend adding a 5.25" mid to bridge the gap but if you're stuck on a two-way, I think your best bet would be to look into a full-range 2" or 3" (Tang Band and Fostex are my favorites) though you might also try LPG's 51AT (There's your titanium )
    You can give the specs to madisound.com and see if they'll make a crossover for you, or you could design your own but as the upper end of the RE8's response might be very unpredictable, I'd strongly recommend going active
    Contour SVT
    Empty hole > Empty holes
    John Edwards
    99concorde's Avatar
    May 2003
    naptown
    31
    196
    not quite sure what you mean. im new to components and car audio in general. ive been reading on the board and everyone thinks components are great. so what i was going to do was build a kick panel for the eight and tweeter and try to buy a crossover. i really wouldnt know how to build a crossover. the guy at a local car audio shop said i should use capacitors? whatever that means. where can i find those tweeters you listed.what does active mean.
    lost
    zephyr's Avatar
    zephyr is offline Senior VIP Member
    Jun 2003
    here
    179
    component system consists of midrange and tweeter; plus midbass ina 3-way set. re8 is more of a midbass/sub driver. it doesn't play higher frequencies very well. therefore you need a midrange and tweeter to go with it. since you are building a custom component, it is better to go with an active crossover. so you can adjust the crossover frequency to the best point. if you want to build passive crossover, you can go to www.madisound.com or www.speakercity.com and have them build it for you. all you have to do is give the driver specs to them. they will determine the best xover point and slope. to buy those tweeters listed above, go to www.partsexpress.com
    Denon - PPI - JL Audio- Image Dynamics - CDT Audio - Hugfen
    b0mbrman's Avatar
    Feb 2003
    233
    Quote Originally Posted by 99concorde
    The LPG is at madisound and the Tang Band is at partsexpress.com (or nuera-acoustic.ca)
    To go active, you need an amp with HP/LP filters. Connect the tweeters to the front channels and the mids (in this case, your RE8's) to the rears and play with the crossover till it sounds right.
    Contour SVT
    John Edwards
  1. ok lets make this the official "LACK OF POWER THREAD"
    By d audio 450 in forum Wiring, Electrical and Installation Help
    Last Post: 02-09-2004, 09:21 AM
  2. 4" componets
    By LBX2G in forum Speakers
    Last Post: 08-17-2003, 04:43 PM
  3. Gotta make me a box could use lots of help
    By iwantmorebass in forum Enclosure Design & Construction Help
    Last Post: 07-26-2003, 05:02 PM
  4. Replies: 4
    Last Post: 07-20-2003, 10:46 PM
