Results 1 to 3 of 3
Reload Thread: 3-way Comp. Requirements?
    brh1400's Avatar
    brh1400 is offline Junior Member
    Sep 2003
    Baltimore
    Alright, I'm very new to car audio, but I'm looking to replace the stock stuff in my '99 Pathfinder. I've been looking around at speakers and was wondering, what would owning 3-ways entail? These are the questions that have been bugging me, and any information would be extremely helpful.
    Would I put the 4" mid and the tweeter in a kick panel and put the woofer in the door panel?
    Would a 4-channel amp be necessary to power the component set?
    Finally, if the component set is 150rms, I could get away with giving it 85 or 100, right?
    Again, thank you very much for taking the time to respond and answer my questions. Your help is greatly appreciated.
    ws140's Avatar
    ws140 is offline ~`[]D[]][\/]][[]D`~
    Oct 2002
    MA
    33
    671
    Your suggested speaker location would work well. Also you can send them as much power under 150 watts as you want. Anything from 50watts up would sound good. A 4 channel amp would give you the ability to either run the components speakers and some rear speakers or to run the mids and highs off 2 channels and bridge the 2 other channels to run the woofers.
    Alpine CDA-9813
    Infinity Kappa 60.5s Component Speakers
    U.S. Acoutics 2080x for the comps (80x2 @ 4 ohms)
    1 ed e12O.44 in a 2ft.^3 sealed box.
    Soundstream RUB500-1 for the sub (400x1 @ 2 ohms)
    adam71's Avatar
    adam71 is offline P9 = Ultimate SQ
    Jul 2003
    Michigan
    5,795
    Re: 3-way Comp. Requirements?
    Quote Originally Posted by ws140
    Your suggested speaker location would work well. .
    Agreed. Thats where mine are located. Great sound stage.
    You could also run the 4's and tweets off of 2 channels and run the 6.5's off the other 2 channels. I bought a pair of MBQuart 3 way crossovers and use them with my NON MbQuart drivers. The Xovers allow bi amping. therefore I can use seperate amps for the midbass and sepreate amp for the mids and highs. Just my 2 cent. :p
  1. The Funniest bass comp you've ever been to??
    By Luzah in forum General Discussion
    Last Post: 08-12-2003, 12:00 AM
  2. Dual 12 Kicker Comp Slot Ported Box
    By jwrbl17 in forum Enclosure Design & Construction Help
    Last Post: 07-31-2003, 03:49 PM
  3. SQ comp tomorrow..wish me luck
    By taylor in forum General Discussion
    Last Post: 07-28-2003, 07:14 PM
  4. Went to my first comp.. competed
    By more_spl in forum General Discussion
    Last Post: 07-26-2003, 01:15 PM
  5. just got back from a comp
    By jinx8402 in forum Subwoofers
    Last Post: 07-26-2003, 11:14 AM
