Results 1 to 6 of 6
Reload Thread: 2004 Volvo S60-R speaker questions
    firehawk618's Avatar
    firehawk618 is offline Member
    Feb 2009
    Marysville, wa
    45
    Hello, I am new here but have been doing alot of reading but have not found an answer to a few questions.
    1st is I have a 2004 Volvo S60-R and it had the premium sound system that has an amp under the drivers seat. That amp powers all the speakers in the car EXCEPT the center one on the dash, that one is powered off the factory deck. Does anyone know what impedance the speakers in this car are?
    2nd is there a good 5 channel amp that is not using the 5th channel for subs? I would like to install just one amp and power all the speakers in the car except my subs.
    Thanks
    dlschevy's Avatar
    dlschevy is offline afrias
    Jan 2008
    mty, mex
    47
    Re: 2004 Volvo S60-R speaker questions
    Some volvo use factory dynaudio speakers, i don,t know about your car, but in my opinion use the factory amp and the speakers and only install another amp for a sub ....i recomend a good sub, like a DLS ..
    Kenwood 591
    Front stage - MS6A
    Rear stage - UX26
    Substage - Iridium 10 "
    Amps set - RA50
    Wiring - DB Link
    Security - Viper 5002
    dlschevy's Avatar
    Jan 2008
    mty, mex
    47
    also change the factory HU.....
    Kenwood 591
    Front stage - MS6A
    Rear stage - UX26
    Amps set - RA50
    Wiring - DB Link
    Feb 2009
    Marysville, wa
    45
    Thanks for the super fast response! However the factory deck is already shelved, and the factory amp was fried...long story there but it is gone none the less.
    Currently running everything just off hu power and it is pretty bad
    I have no problem putting a 4ch amp in place of the factory amp but I really want to use the center speaker hence the need for a 5 channel amp. I really don't want to add another amp just for the center channel by itself.
    dlschevy's Avatar
    Jan 2008
    mty, mex
    47
    ok i undestand, you can use the five speakers (center too), all than you need is another amp (5 channel) only conect all correctly and no problem...
    Kenwood 591
    Front stage - MS6A
    Rear stage - UX26
    Amps set - RA50
    Wiring - DB Link
    Feb 2009
    Marysville, wa
    45
    So anyone know what ohms the factory speakers are?
