Results 1 to 6 of 6
Reload Thread: What's the best adhesive to use for tweets?
    mav2002's Avatar
    mav2002 is offline Senior VIP Member
    Jul 2002
    Los Angeles, CA
    42
    162
    Icon32 What's the best adhesive to use for tweets?
    Okay, so I am way new to this, but had an install question. I have a 2003 BMW and had my rear tweets replaced. I left my car outside in SoCal the other weekend, and it got upwards of 110 degrees OUTSIDE, which probably means what, 140+ inside? Anyhow, my freakin' tweets basically fell out! After looking more at the tweets, they were hanging by the wires (+/- wires) and it looked as if the adhesive melted away. Do car install shops use adhesive to keep these in place?
    If I were to do this myself, what kind of adhesive should I use? In case your wondering, the speakers are Diamond Audio s500s speakers.
    Help!
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    37
    8,477
    32
    Go to Home Depot and look around in the glue section and find an epoxy that can withstand very high temperatures...
    "The world is full of people who want nothing short of perfect,
    but settle for less, blinded by their quest for purpose."
    - Slug
    mav2002's Avatar
    Jul 2002
    Los Angeles, CA
    42
    162
    Re: What's the best adhesive to use for tweets?
    Quote Originally Posted by Gauntlet
    Okay, I'll give that a try. Thanks!
    bri487's Avatar
    bri487 is offline Banned
    Feb 2003
    birth canal
    7,431
    check out 3M double sided foam mounting tape. this stuff can handle quiet a bit of load on it. also check out 3M's interlocking plastic velcro. i have used this stuff to mount a lot of things, even my ignition in my car. when it came time to remove it, i had to pry it off with a screwdriver, lol
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    My vote would be for RTV. Certailnly strong enough for a tweet, good temperature rating, and not totally permanent like epoxy.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    bri487's Avatar
    Feb 2003
    birth canal
    7,431
    Re: Re: What's the best adhesive to use for tweets?
    Quote Originally Posted by maylar
    too messy. and it is too soft, when mounting something, i would want it to for sure stay in the same place i put it. i have used it before and it is not a stable enough base for them to rest on. you would have to mount them two or three times to get the adjustment just perfect, where as velcro or mounting tape would be much easier.
