Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Reload Thread: diamond audio comps ****??
    TypEL's Avatar
    TypEL is offline Member
    Jul 2002
    Vancouver,BC
    57
    i bought a set of s600s DA hex components...and ive noticed that they aitn that great..i was told that their top of the line kinda stuff like Focal polykevlar level
    im running them off a Eclipse 32440 amp...one side per channel
    gain is at 50% which khz around 110-120
    on my deck bass is at 0 treble is at 0 balance/fader even
    my problem is they cant take much power it seems like..and they dont have no midbass u cant even hear bass out of them unless basss is at +7 on the deck
    to the power issue.......around volume 23 and up they sound like total crap....basically start farting in a way....ive had 100$ speakers sound better then these
    at volume 20 they sound fine...pretty clear but no midbass at all...tweets are nice..but volume 20 doesnt really satify my needs..i tried tuning it for volume 25 no higher
    ne who wat did i do wrong with them..if anything..yes they are in stock door locations...other then that i can think of anything..maybe connect + to - like the manual says or sumthin?
    thanx ahead
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    36
    8,477
    32
    Re: diamond audio comps ****??
    Quote Originally Posted by TypEL
    What do you mean khz around 110/120? If you have your high pass set to that frequency, then that is causing your problem. Put it down anywhere between 70 and 90 and you should get more midbass....
    "The world is full of people who want nothing short of perfect,
    but settle for less, blinded by their quest for purpose."
    - Slug
    slick316's Avatar
    slick316 is offline CarAudio.com Elite
    Mar 2003
    Moore, OK
    35
    530
    yea, 110-120 is too high, needs be a lot lower. i have mine set at 70hz, sounds great with a lot of midbass.
    2005 Honda Accord EX Sedan
    JL Audio Cleansweep, JL Audio ZR650-CSi, JL Audio 12W3v3 in custom stealthbox like enclosure in trunk, JL Audio A6450, Audiocontrol DQXS w/DDC
    Home:
    Sony 32" XBR BRAVIA LCD, Toshiba HD-A1 HD-DVD Player, B&W 704 Floorstanders, Rotel RC-1070 Pre amp, Rotel RB-1070 amplifier (130x2), Rotel RCC-1055 5 Disc Changer, HTPC as music server and PVR, and XBOX 360.
    TypEL's Avatar
    Jul 2002
    Vancouver,BC
    57
    well i put it between 70-90 mid bass was a little better in my garage wi/o the car started
    but they still ****...the distort on volume 22-25 and lack the midbass
    maybe not enuff power? 85 rms to each side right now
    Bavarian3's Avatar
    Bavarian3 is offline Ownz joo
    Mar 2003
    Nor*Cal
    31
    5,170
    1 Post(s)
    Re: Re: diamond audio comps ****??
    What u need is an amp for them. Runnin components off a deck doesnt work too well...
    Upcoming SQ competition ready install...
    -Eclipse cd8053
    -Image Dynamics Cd1Pro MH
    -Image Dynamics 6.5" mids with CX motors and poly cone in custom fiberglass kick panels
    -12" Stereo Integrity Magnum in large sealed fiberglass wheel well enclosure.
    -Viper d1200.1 (sub), Viper 400.2 (mids), David Navone Amp-100 (horns)
    TypEL's Avatar
    Jul 2002
    Vancouver,BC
    57
    they are off a amp.eclipse 32440....right now im using channels 1 and 2....1 to one side 2 to other...80-85 rms each side
    think they need more juice?...i can use channel 1&2 for one side and 3&4 for the other...get around 150 rms per side or more
    Bavarian3's Avatar
    Mar 2003
    Nor*Cal
    31
    5,170
    1 Post(s)
    oooh my bad ii thot the eclipse u were talkin about was a deck. I dont know what ur problem is then....Diamond Hex's are supose to be awesome components. Make sure ur gains arent set u high and make sure the crossovers are set properly as well as the crossover on the amp. dont use the bass boost either. Then mess with ur settings on ur deck, what kinda deck do u have btw that can make a big difference
    -Eclipse cd8053
    TypEL's Avatar
    Jul 2002
    Vancouver,BC
    57
    alpine 7875
    gain on the amp is at 50%
    on the deck bass is at 0 treble 0...the EQ on the deck doesnt seem to do much..ill play around with it more..but doesnt make a whole of a diff
  9. #9
    slick316's Avatar
    Mar 2003
    Moore, OK
    35
    530
    power shouldn't be an issue, i was running 300 watts to each (way too much power), but no difference from when i run 75 watts. i heard a set of HEX's in an S2000 running off one of those new 2 channel JL e series amps, amp only does 45 watts x 2 @ 4 ohms and the speakers still sounded great with tons of midbass. sound deadening will help, and make sure there isn't a phasing problem, i had that problem with mine once. other than that, i have no idea whats wrong, sorry.
    Home:
  10. #10
    Matador's Avatar
    Matador is offline -= StillBumping =-
    Oct 2002
    Ca
    2,093
    alpine 7875
    try to set the gain correctly again. u should match hte gain to the input of ur hu. diamond r supposed to be very good comps
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    www.angelfire.com/falcon/matador updated 5/02/03
    [email protected]
  11. #11
    HarleyF150's Avatar
    HarleyF150 is offline Senior VIP Member
    Oct 2002
    Louisiana
    270
    yeaaaa
    well 1st off i would like to say that diamonds are no where near crap. Sounds like to me bad install/wiring problems. They dont need any more power than that either. If you installed it yourself thats the problem. Personally, i would take it to a different shop and get them re installed and all your wiring redone. Thats just my opinion. But one things for sure you cant get a much better set of comps than the Hex's. Good luck,
    Mike
    Email: [email protected]
    2002 Chevy Tahoe
    Pioneer 8600
    6.5" PG RSD's
    Profile California AP1000
    12" Diamond Audio D6
    Crunch PZI 1000.1
  12. #12
    TypEL's Avatar
    Jul 2002
    Vancouver,BC
    57
    connections and u can adjust tweets
    well imma go through all the wiring as we speak.....just to make sure i didnt do a + to - connection but im sure i didnt make a mistake on both sides if i did make any misatke
    the x-overs are simple power tweeter and midwa
  13. #13
    Jun 2003
    Thief River Falls, MN
    48
    128
    sorry to hear you are not impressed with them.
    i love mine after 4+ years now.
    diamond 600.25 hex's in kicks with 200 a side.
    right now they are crossed at 35 from an audio control 2XS. which is a 18db slope from that xover. was running them off the HU xover which was 40 and 6 db slope.
    have ran them full range. but they did not care to much for that.
    have ran 50 to each side but when i got a dedicated sub amp i bridged the 4 channel amp i had for 200x2.
    sounds like a phase issue to me.
    Monty
    excelon|PPI|Tsunami|eD|Diamond Audio|peal and seel|
    USACI b-stock 601+ best of 153.3 aiming for 155
    dbdrag street A best of 143.5 on new sensor
  14. #14
    LBX2G's Avatar
    LBX2G is offline R.I.P Camofluage
    Jun 2002
    Warner Robins
    33
    2,713
    hey how many comps do you have if u have 4 sets then why are u using only 2 channels of an 4 channel amp. I hate when people do that. But some times compents can be very diffcult to work with. You just need to experament with them. and move the tweeter closer to the woofer that will give u better midbass reponse.
    -holla at ur boi
    FREE Terrelll"peanut" Grayer!!!!!!!!!!!!!!!!!!!!!!!!!!
  15. #15
    DARKHART's Avatar
    DARKHART is offline One Hitter Quitter
    Aug 2002
    LITTLE ROCK, AR
    2,290
    197 Post(s)
    Quote Originally Posted by LBX2G
    -holla at ur boi
    Moving the tweeter closer to the woofer will not give you better midbass response, it may improve on total imaging of the driver combo but the tweeter has nothing to do with the response of the midbass driver...
  1. Car audio & electronics mag
    By djjdnap in forum Amplifiers
    Last Post: 06-09-2004, 01:19 AM
  2. 10xe MA Audio Sub... Any good?
    By jlaudiow6 in forum Subwoofers
    Last Post: 07-27-2003, 11:28 AM
