Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: add on tweeters
    loud-n-low's Avatar
    loud-n-low is offline i give ladies 30mm xmax
    Aug 2005
    upstate NY
    34
    2,658
    1 Post(s)
    add on tweeters
    im looking to add tweeters to my existing setup, and not sure what to buy. Boston acoustics makes imaging tweeters, but im looking for other companies that sell tweeters with crossovers. woofersetc sells image dynamics tweets but i dont think they include a crossover. do i need a crossover since they will be hooked up to an aftermarket amp?
    snfsh79077's Avatar
    snfsh79077 is offline Ladie's like my pole
    Sep 2003
    bay st. louis/baton rouge
    24
    2,297
    Re: add on tweeters
    I have some jbl gto tweeters that came with crossovers that work great as imaging tweeters. Your going to want a crossover if your not running active. CDT makes an imaging setup as well.
    HU: Kenwood KDC-X993
    Front stage: (2x) Shok CB 6.5
    Comp amp: Crescendo 1000c4
    Sub stage: (2) AQ HDC3 10s in 2.3 cuft @ 38hz
    sub amp: Crescendo 3kw
    Electrical: Mike Singer 250a alt w/ext regulator, D3100, NSB100, D680, 50ft of shok cca
    149.5 @ 39hz and climbing...
    Plenty of refs between here and caco....
    Horsemanwill's Avatar
    Horsemanwill is offline CarAudio.com Veteran
    Aug 2008
    Junction City, Kansas
    2,973
    1 Post(s)
    Re: add on tweeters
    it would be better yes, ba makes some so does mb quart and a few others basically all you really need is to make sure the low freqs aren't going to the tweet and you should be ok
    Pioneer Carrozzeria DEH P01
    Tru SB6
    Silver Flute W17RC38-08 6-1/2" Wool Cone
    Tru Steel S25
    ES Full body horns soon to come
    2x JBL W12GTI
    loud-n-low's Avatar
    Aug 2005
    upstate NY
    34
    2,658
    1 Post(s)
    Re: add on tweeters
    i ran the bostons before. noticed that they are 8k and up. isnt this kind of high?
    snfsh79077's Avatar
    Sep 2003
    24
    2,297
    Re: add on tweeters
    if you interested I believe these are the ones I have but I bought them so long ago I dont really remember.
    http://cgi.ebay.com/JBL-P25T-1-TWEET...3286.m20.l1116
    loud-n-low's Avatar
    Aug 2005
    upstate NY
    34
    2,658
    1 Post(s)
    Re: add on tweeters
    im adding these to my front end which consists of 6.5inch 4 ohm coaxials. im tapping in to the coaxials with the tweeters so will that make my amp see a 2 ohm load if the tweeters are 4ohm?
    snfsh79077's Avatar
    Sep 2003
    24
    2,297
    Re: add on tweeters
    Quote Originally Posted by loud-n-low View Post
    If you wire them parallel your amp will see a 2 ohm load, if you wire them in series your amp will see an 8 ohm load.
    I used to just have 6 1/2 3 way eclipse coaxials and I added the jbl tweeters and I noticed a huge difference.
    Trey803's Avatar
    Trey803 is offline GAMECOCKS
    Jan 2006
    USC
    5,540
    Re: add on tweeters
    do it right and buy components
    HU: DEH-P880PRS
    Doors Deadened
    Front Stage: Rainbow SLC 265
    Front Stage Amp: Alpine MRV-T420
    Sub: FI Q [for sale or trade]
    Sub Amp:
    Wire: Knu
    Quote Originally Posted by Rashaddd View Post
    the ladies love my mounting depth.
  9. #9
    loud-n-low's Avatar
    Aug 2005
    upstate NY
    34
    2,658
    1 Post(s)
    Re: add on tweeters
    my car is a lease, so im not doing anything major. some add on tweeters are 8 ohm, some are 4 ohm. not sure which would be better as an add on due to combining them with 4 ohm coaxials
  10. #10
    snfsh79077's Avatar
    Sep 2003
    24
    2,297
    Re: add on tweeters
    try to get 4 ohm to initially see a 2 ohm load in parallel. What coaxials do you have?
  11. #11
    loud-n-low's Avatar
    Aug 2005
    upstate NY
    34
    2,658
    1 Post(s)
    Re: add on tweeters
    pg rsd's
  12. #12
    jdawg's Avatar
    jdawg is offline CarAudio.com Veteran
    Jun 2006
    Maryland, United States
    8,608
    1 Post(s)
    Re: add on tweeters
    just about any car audio add on tweeter you see come with a little in line crossover, or atleast the have a capacitor which is a 6d roll off, you should be fine either way
    refs
    woc47, nigro013, defconx3, louisiana_crx, bld 25, supa_c, lancer1978, sxkicker89, 310w6, more, i forget
  13. #13
    loud-n-low's Avatar
    Aug 2005
    upstate NY
    34
    2,658
    1 Post(s)
    Re: add on tweeters
    the arc audio tweets are cheap on woofersetc. they are 25 watts rms, but 50 watts music power handling? so is that 50 rms with music?
  14. #14
    snfsh79077's Avatar
    Sep 2003
    24
    2,297
    Re: add on tweeters
    pg rsd's
    well how much are you looking to spend. You should be happy with those jbls but you could also get some mb quarts
  15. #15
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    9,576
    12 Post(s)
    Re: add on tweeters
    do a set of comps and velcro the tweeter housings in place. Seems like much less hassle and probably better sound...
