Results 1 to 9 of 9
Reload Thread: 2005 Chevy crew cab
    capecodder's Avatar
    capecodder is offline Junior Member
    Nov 2008
    cape cod Ma.
    14
    2005 Chevy crew cab
    New member here so hello to everyone.
    I have a factory set-up in a chevy crew cab and want to improve it with just replacing the speakers for now. There is so much out there and is very confusing to tell what I am looking at being a complete novice.
    The only place I have looked at for speakers has been Crutchfield but I have been buying home audio from them for twenty years.
    What does everyone feel would be good choices for reasonable money for full range speakers for my truck? Might want to add a head unit and a sub at a later time but for now I just want to get rid of the horrible factory speakers that are in there.
    Thanks in advance!!
    WildSebring's Avatar
    WildSebring is offline Uncle Bobby B baby
    Mar 2008
    Dallas Texas - Land of DSR
    1,780
    Re: 2005 Chevy crew cab
    Any decent component set would sound nice...but not going to get full potential out of the stock headunit.
    Whats your budget like ?
    Refs: Andrew2944r, RyanM923, BASSMEKANIK, Sundowz, Rusty...WCA, TeZ, William Brea, LExus300, amp junkie, DUMPED, and tons more..
    99 Regal GS - SUPERCHARGED B|TCH
    capecodder's Avatar
    Nov 2008
    cape cod Ma.
    14
    Not very high at this point with small kids in the house. They are like a vacuum to the wallet.
    hatemonger's Avatar
    hatemonger is offline funded*by*soros
    Mar 2006
    Denver, Co
    37
    9,025
    win an auction on ebay, and get an amp. i got an mtx 2002 for 16$, and it runs my components pretty well.
    2003 chevy s-10 ext. cab
    hu: jvc kd-avx1
    precision power 356cs components
    front amp: infinity 475a
    sub: diamond audio d6 10d4
    enclosure: 1.1 cubes ported tuned @ 31hz
    sub amp: JL G1700
    Oct 2008
    columbus, oh
    864
    http://www.woofersetc.com/index.cfm?...roduct_ID=6201. These are the speakers I would recommend if they're within your budget. They're a nice set of speakers.
    Louisiana_CRX's Avatar
    Louisiana_CRX is offline dem shoes...... Louisiana_CRX is a Supporting Member of the forum!
    Aug 2006
    Piney Hills of Louisiana
    34,141
    31 Post(s)
    check on ebay for a set of Phoenix Gold RSD 6.5's they use to run $87 a pair shipped ...good componets for the money...if I remember right your model truck has the doors that are perfect for componets behind the mesh grill.....or that could be a little older chevy doors I'm thinking about
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
    capecodder's Avatar
    Nov 2008
    cape cod Ma.
    14
    Quote Originally Posted by Louisiana_CRX View Post
    My doors have the mesh grille in them. are these the ones your talking about?
    http://cgi.ebay.com/NIB-PHOENIX-GOLD...1%7C240%3A1308
    I've never hooked anything like these up before. As I said before, I still have the stock head unit.
    capecodder's Avatar
    Nov 2008
    cape cod Ma.
    14
    Well I talked with a tech guy at best buy and he said to make sure it isn't the head unit as delco units are know for faile channels. sure enough both rear channels ar dead now so it sounds like a complete overhaul.
  9. #9
    dye4metal's Avatar
    dye4metal is offline CarAudio.com Elite
    Jan 2008
    Tampa, Fl
    21
    708
    Quote Originally Posted by capecodder View Post
    im actually buying myself a 03 CCSB duramax also and ive already planned out my whole system already for it. anyways, i would recommend for you since the rear channels took a crap then to just swap the headunit out overall. it all depends on what your budget is, but i just installed one of these into a 08 f-150 and made a huge difference http://www.crutchfield.com/p_130P800...T.html?tp=5684 its 300 dollars right now and comes with everything you need to install it free and shippings free. there is a module you need though in all 03+ for the door chime, and if you have onstar i think theres something else. other than that id recommend like a Alpine Type S component set in the front with the woofer and tweeter in the factory spot and put coaxial in the back. youll notice a huge improvement. just PM if you want any more ideas, like i said im buying one this week and im stoaked.
    Dodge Ram 2500 4x4 Laramie Cummins Diesel
    Kenwood DNX8120
    Soundstream Rubicon 2500.1
    Treo SSX 15
    refs: xxBURT0Nxx,adas3,fasfocus00,FRITO,bigbangtheory,on yxaltezza,Brian Owens,spracer03,NewAgeKing,IbSlamn,TheLow,captainc heesey,FarrisAudio,TeZ,devin1231,HvNd4Speed,Neel,c reater,Jeffrofosho,scottyk,budahbuddy803, BigEM, Bradfordpoole, DARKHART,blkmrideon22s
