Results 1 to 12 of 12
Reload Thread: 4" Low Power (High efficiency) Speakers for Geo Metro
    Justintoxicated's Avatar
    Justintoxicated is offline CarAudio.com Elite
    Jun 2005
    San Diego, CA
    885
    I have a 91 Geo metro with Eclipse 3200 CD player.
    I tried using some 3.5" infinity speakers (say 25w RMS) from my friend but I can only hear the tweeter working and they sound like crap and not very loud off the HU power, so I went back to the stock 1991 paper speakers.
    I want an upgrade but nothing too crazy...
    Would these full range drivers work just powered by the head unit?
    http://www.parts-express.com/pe/show...number=295-378
    or would I be 1000x better off with these IDs
    http://www.woofersetc.com/index.cfm?...Product_ID=909
    or
    http://www.arcaudio.com/productdescr...ies/ks4026.asp
    I do have an 75x2 @ 4ohms amp but I was going to power a small sub with it, if it will be necessary for the front I'll just forget about adding a woofer for now.
    I'm not really fond of any 4" speakers but I don't think its worth doing a custom install into the doors of this vehicle. I have some old Kenwood excelon pink cones that would be shallow enough, but I figured the factory look would keep it simple.
    Also it has 4x6's in the rear, should I disconnnect them or get some 4x6 to help out with volume and rear fill?
    Truck:
    Nissan Titan KC
    HU:
    Eclipse CD7200 MKII HU
    Speakers:
    DLS Iridium 6.2 Front Stage
    TC1000's,
    AMps:
    Arc Audio XXK 2100 for fronts, Diamond Audio D5 1200.1
    Other:
    Knukonceptz 0 & 4ga and all Speaker wire and Streetwires 0 ga Power/Ground Distro Block, 4.5 rolls 60 mil RAAMAT and Ensolite foam througbhout, Kintetik HC2000 The Big 3 + 0ga Gounding Kit.
    Horsemanwill's Avatar
    Horsemanwill is offline CarAudio.com Veteran
    Aug 2008
    Junction City, Kansas
    2,974
    1 Post(s)
    Re: 4" Low Power (High efficiency) Speakers for Geo Metro
    those ID speakers are great speakers to run off a deck i've used a set in 3 different vehicles now. i'd say since it's only 4's i'd go ahead and get you a set of 4x6s to fill out the vehicle.
    Pioneer Carrozzeria DEH P01
    Tru SB6
    Silver Flute W17RC38-08 6-1/2" Wool Cone
    Tru Steel S25
    ES Full body horns soon to come
    2x JBL W12GTI
    Hoodlum007's Avatar
    Hoodlum007 is offline CarAudio.com Veteran
    Apr 2003
    Reno Nv
    2,008
    Agreed, the ID Coaxils and comps sound awesome.
    Jun 2005
    San Diego, CA
    885
    Ok this sounds good since I like silk tweeters, anyone know where I can get a decent price on them I don't wanna spe nd too much money on a $1000 car $100 is already pusing the budget. Think I could get by with just one set? Amping one set would be cheaper than buying both fronts and 4x6's for the rear.
    Truck:
    Nissan Titan KC
    HU:
    Speakers:
    TC1000's,
    AMps:
    Other:
    bass_lover1's Avatar
    bass_lover1 is offline Metal Head \m/ \m/
    Jun 2004
    NPR, FL
    27
    1,574
    The RS100s are great drivers, the pair I have is gonna go head to head with my L3s for a spot in the car.
    The only issue with the RS100s is that after about 6-7k hz unless they are directly on axis, you're going to lose quite a bit of output. Great speakers, but they're at home more in a 3-way setup as a dedicated midrange, or a low powered 2-way system, like bookshelf speakers.
    I think in a vehicle, if all you're going to have running is 4s up front, you'll probably be better off with the IDs. Though whatever you end up choosing, I wouldn't expect any type of usable output below 160hz, a simple HP crossover is something I would look into.
    - Alpine CDA-9887 - AudioControl DQS - Linear Power 652I - B&G Neo3 - Clarion DPX 2251 - Vifa XT18 - Clarion DPX 1851 - Alpine SWX-1243D -
    Ridinhi's Avatar
    Ridinhi is offline CarAudio.com Veteran
    Aug 2006
    NC
    2,807
    6 Post(s)
    pm sent
    Oct 2007
    239, Florida
    25
    1,928
    Geo Metro=******
    Team Decent Member
    Buck's Avatar
    Buck is online now always low Buck is a Supporting Member of the forum!
    Buck is a Supporting Vendor of the forum!
    May 2008
    Nashville
    17,506
    150 Post(s)
    Personally, I wouldn't worry about buying speakers but a new car....
    Bought from: kmanian(x2), KyleBetchtold, Rio, 05_ZX636, SoCalNoob, dave_damage
    Traded with: cj407, twistedchild420
    Sold to: jadon087, dvldogyut, 95saturn, many box designs...
    Click for High Output Enclosures Email (formerly Buck Box Designs)
    I do sealed, ported, t-line (consistent width), 4th and 6th order bandpasses.
    I answer any audio questions sent to my email for free.
    Alpine - CT - ASE (local) - Batcap - C&D Tech - DC - eD - Excessive Amperage - Rainbow
    In Nashville? Me too! Pm me and come hangout!
  9. #9
    Jun 2005
    San Diego, CA
    885
    I have another car, this is my commuter 40+ MPG on the freeway. But it only had an FM radio and paper surround speakers. I just wanted some tunes and bluetooth but want to hear music rather than distortion from the crappy speakers.
    Anyways I guess I will just go with some ID's up front and then see if I want 4x6's in the rear too.
    I believe my Eclipse HU already has a high pass crossover, I'll probably cut them off at 180htz or higher anyways. My amp definately has one as well if I decide to amp them.
    Truck:
    Nissan Titan KC
    HU:
    Speakers:
    TC1000's,
    AMps:
    Other:
  10. #10
    loudcartunez's Avatar
    loudcartunez is offline CarAudio.com Veteran
    Nov 2007
    philly pa
    2,109
    i have some rockford 4'' speakers brand new in the box if u wanna buy them $25
    04 Mazda 6 dropped on speed wheels
    1 soundstream t4-15 ported threw rear deck
    concept 2410d
    o2 4 channel
    jl 4 channel
    three 6" prv audio one 8" prv audio mids and tweeter in each door
    refs
    http://www.stevemeadedesigns.com/board/index.php?showtopic=13530
    http://www.caraudio.com/forum/showthread.php?t=278829
    http://www.realmofexcursion.com/forum.html
  11. #11
    Jun 2005
    San Diego, CA
    885
    How would those fosgates compare to something like these?
    http://www.onlinecarstereo.com/CarAu...roductID=19915
    Or those vegas someone posted me.
    The JBL's look pretty nice and might be good eough for the geo? I can get them fairly cheap like around $60 a set.
    Maybe get these for the rear?
    http://www.onlinecarstereo.com/CarAu...roductID=19919
    Truck:
    Nissan Titan KC
    HU:
    Speakers:
    TC1000's,
    AMps:
    Other:
  12. #12
    Jun 2005
    San Diego, CA
    885
    So now I'm thinking to go with Pioneer or Phoenix gold so I can replace all 4 speakers for cheap.
    Whats better
    http://www.onlinecarstereo.com/CarAu...roductID=17549
    or
    http://www.onlinecarstereo.com/CarAu...roductID=19140
    Open to other suggestions too. I don't really like harsh sounding tweeters like aluminmum or titanium. I want to keep the total for these + 4x6 version to under $100
    Truck:
    Nissan Titan KC
    HU:
    Speakers:
    TC1000's,
    AMps:
    Other:
