Results 1 to 9 of 9
Reload Thread: best 6.5 component set under $350?
    nismboy6986's Avatar
    nismboy6986 is offline the **** technician
    Jul 2002
    Belhaven NC
    665
    what do u think would be the best component set for under 350 online at at a place other than ebay. I want some with really strong midbass and vocals. i'm kind of looking at the ID CSX 6.5 and the diamond audio S600's. it also needs to be able to handle a Axionixx AXA 400.2 which puts out 100 watts a channel at 4 ohms, 200 at 2 ohms at 12.5 volts for those who didn't know that. which kind of kills my idea of getting the CDT classics at 150 from the zeb.com
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    32
    8,480
    32
    Kodas - one of the stronger midbasses out there, www.adireaudio.com
    "The world is full of people who want nothing short of perfect,
    but settle for less, blinded by their quest for purpose."
    - Slug
    mr.juice's Avatar
    mr.juice is offline Member
    Apr 2003
    minnesota
    53
    eclipse component series
    Froggie's Avatar
    Froggie is offline Junior Member
    Jun 2003
    oh
    40
    why would that kill the CBT 150.00 deal?
    Jul 2002
    Belhaven NC
    665
    not kill the deal but kill the particular ones i would get. A component set rated at 90watts rms getting powered by amp that puts out 100watts at 12.5 volts can't be to good for said component set. but aren't the kodas 380 and close to 400 when u include shipping?
    outbacksport's Avatar
    outbacksport is offline Senior VIP Member
    May 2003
    S Cal
    309
    Focal 165 K2 6.5" Component System for $329 at cbrstereo.com
    Specifications:
    2-way separate system.
    165mm (6-1/2") midbass,
    40mm (1-3/8") v.coil,
    100mm (4") magnet.
    TN 45 tweeter.
    2-way separate high-pass
    crossover 18 dB/oct. (3.5kHz).
    Adjustable tweeter level.
    Max. power handling: 200W.
    Nominal, power handling: 100W.
    Sensitivity (2.8 V/1m): 92dB.
    Frequency response:
    60Hz-20kHz.
    Removable woofer grill
    included.
    Add $19 and you got a MB Quart "Q" Series QM 218.61 6.5" Component Set
    $369 at the same site
    Specs:
    Impedance: 4 Ohms
    Frequency Response: 48-32k
    Sensitivity: 86 dB
    Power Range: 90-170 watts
    Crossover Freq: 2600Hz Hz
    Crossover Slope: 18 dB/octave
    But i where you, go out and listen to them first.
    bri487's Avatar
    bri487 is offline Banned
    Feb 2003
    birth canal
    7,439
    the focal 165W3, not jk, they are $1680! the focal 165A runs for about 300. i would go with either the 165A's or the Eclipse SP8362's which retail for around 350
    jlaine's Avatar
    jlaine is offline Vaporware
    Apr 2002
    Morris, MN
    2,607
    Works for me...
    And for my USACi Pro 301+ car.
  9. #9
    joshpoints's Avatar
    joshpoints is offline CarAudio.com Veteran
    Jan 2003
    San Ma Tonga Central, CA
    29
    3,165
    Planet audio, Infinity Kapa, Alpine type r
