Results 1 to 7 of 7
Reload Thread: Need help with focal speakers mounting depth
    Mindspin311's Avatar
    Mindspin311 is offline Member
    Dec 2002
    ATL Suburbs
    28
    135
    Unfortunately the 6.5 coaxials that i bought for my Blazer's rear doors dont fit because the door is too shallow. Does anyone know the mounting depth of the 165ca's and the 130ca's?
    Randy Savage's Avatar
    Oct 2002
    New York
    28
    21,083
    4 Post(s)
    Did you check their website?
    You may be able to get those to fit...you can take a piece of wood, and cut it to fit in the door, which will give you extra room for the depth...
    Dec 2002
    ATL Suburbs
    28
    135
    Website says nothing, there is no way to make them fit, I would either cut into the door which will compromise its safety or mount it higher but then it would protrude out of the door panel and look ghetto.
    outbacksport's Avatar
    outbacksport is offline Senior VIP Member
    May 2003
    S Cal
    309
    The 165 ca has a depth of 66.2 cm or 2.6" , the 130ca has a depth of 57.2 cm or 2.25"
    Basis
    http://www.focal-america.com/catalog...dfs/r165CA.pdf
    http://www.focal-america.com/catalog...dfs/r130CA.pdf
    You will need a spacer for the 6 1/2", i used 3/4" spacer made out of mdo
    to fit in my subaru doors. How much space do you have in your doors by the way?
    Measure them and offset it with a spacer to fit the speakers. You should also
    check if it will hit the door panel when you replace it back. Good luck.
    Dec 2002
    ATL Suburbs
    28
    135
    Basis
    Thanks for finding that for me. I might just get the 130's and get an adaptor to fit it to a 6.5" opening.
    May 2003
    S Cal
    309
    Any time, enjoy your focal speakers they sound really good for front soundstage
    plus a good sub your set.
    bri487's Avatar
    bri487 is offline Banned
    Feb 2003
    birth canal
    7,439
    dont cut the doors, that is the last thing i would want to do. if you are mechanically inclined, fabricate an aluminum spacer however thick you need it to be. then if you want to get really technical, make the spacer a wedge so that you can get the sound pointed in the right direction
