Results 1 to 13 of 13
Reload Thread: Comps sound horrible in dashboard?
    B_Rad_NC's Avatar
    B_Rad_NC is offline Member
    Mar 2007
    c
    25
    60
    I just replaced the front speakers in my catalina with some quantum 5.25 comps, i made mdf baffles for them so they mount perfectly to the dash, and are sealed around the mdf with silicone, i have the tweeters in the center console pointing outwards. I also put egg carton foam behind the speakers under the dashboard. Maybe i put too much foam? Theres an assload packed in there and there wasnt much room to begin with. So the speakers basically have no room at all behind them. Im also thinking maybe its the staging or whatever and where i got the tweets at. Also there is NO low or mid bass to speak of coming from them now, excursion is fine, and it seems like the bass should be there, because everythings hooked up correctly. I have a set in another car but in the rear dash and they sound great. Anybody have any advice? Im not running these on an amp btw.
    phyphoestilic's Avatar
    phyphoestilic is offline Liquid Fire...
    Jul 2006
    Riverside, CA
    25
    5,554
    Re: Comps sound horrible in dashboard?
    ....... do u even know the difference between stereo and mono?
    Lexus LS400 Setup
    Eclipse CD7000 (Running Active)
    Image Dynamic OEM CX64s
    Image Dynamics NX30 Tweeters
    US Acoustic USF600 x2, USF800 x2 (Zed Audio )
    150ft+ of Rammat
    IDMax12 1.5cft. I need to cut for IB
    25 feet 1/0 Stinger Expert, 15 feet 4 Stinger Pro
    Stinger Dream Series, Knu Konceptz Krystal Series RCAs
    Ref: (Bought From)Renegadesrun, IonSQL, CrazyJoker2, Alpine CDA-9815 , FI Car Audio, yournumber1dan , B_Campbell, jacobcopeland87, mike dressure x2, James_Bang, blue200sx
    (Traded w/) Iceteebone, sxkicker89
    (Sold To): James_Bang, timbo12, gsxrjjordan
    Ebay: PhyPhoestilic (100%)
    jmanpc's Avatar
    jmanpc is offline CA.com Nostalgist.
    Jan 2006
    Jacksonville, Fl
    25
    17,290
    you're not going to get much bass to speak of out of 5.25s. And why the heck did you mount the tweets in the center console?
    2007 Red Ford Focus ZX4 SE
    - Clarion DXZ955MC -
    - MB Quart RSD216 - 2 MB Quart RWE-354 in 4 cubic feet sealed -
    - MB Quart DSC4125 - Audiopipe AP1500.1D - Optima Blue Top -
    Team High Sexage
    B_Rad_NC's Avatar
    Mar 2007
    c
    25
    60
    actually i dont know the diff between stereo and mono. i dont know that much about car audio **** right now either. But i try. Itd be nice if youd help though instead of posting ******** remarks
    jman was it a bad idea to mount them in the center console? ( its actually in the center of the dashboard, not console) this is my first comp set so im not sure about where to mount the tweets. Ill see if i can get a pic to show you what im talking about.
    PaulD's Avatar
    PaulD is offline self-imposed ban
    Apr 2008
    la la land
    701
    A guy won MECA finals in sound quality for '06 with dash mounted mids, midbass and tweeters I think in the sail panels (iirc, he changed his setup several times during the year). You have to give the midrange some airspace behind them to get any midbass - he used the defroster vents, and try mounting the tweeters in the A-pillars or in the sail panel (the inside triangle where the side view mirrors are).
    standard disclaimer: I know nothing ..... take my advice at your own peril
    Quote Originally Posted by SRim23 View Post
    i think we're between boners at the moment
    jmanpc's Avatar
    Jan 2006
    Jacksonville, Fl
    25
    17,290
    Quote Originally Posted by B_Rad_NC View Post
    You should have mounted the tweeters on the doors or a-pillars or something. With the tweeters in the middle, you won't have very good stereo imaging.
    Team High Sexage
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    9,576
    12 Post(s)
    HU power isn't going to do very much, as you really need an amp to push them. If the HU has a HPF what is it set to? HPF = high pass filter or xover. Should be set to around 80Hz if yours has that.
    Not sure about all the foam, but some deadener on the door might help...
    Jul 2006
    Riverside, CA
    25
    5,554
    basically stereo is when u have a left and right channel (the sounds heard from the left side are not always the same as the ones on the right side) and mono is pretty much when ur only running 1 channel the sounds comming out of 1, 2 ,3 or 20 speakers are all the same.
    The reason u pretty much only see tweeters on the right and left side of the car (and not the middle) is so they can make that right and left channel for a stereo sound to create imaging (which also makes it not sound like crap).
    The only time there should ever be a tweeter mounted in the middle is if you were running 5.1/7.1 surround sound in which case the tweeter in the middle is acting as the center channel, but that'll just confuse u.
    Pretty much like the other people who posted already said, mount the tweeters at the A pillars or sail panels would be the easiest choice. Most cars have stock tweeters at those locations which u might be able to replace with your aftermarket components.
    The midbass drivers do require a certain amount of space, it sounds like they're not getting enough, mounting them on the dash is not always a horrible idea but its not the best. I'm guessing that your lack of bass could be because they're not getting enough power, which is why i also agree with everyone in saying that you should get a amplifier, even a cheap $50-100 2 channel amplifier for the components will sound at least 10 times better then running off the headunit.
    Lexus LS400 Setup
    150ft+ of Rammat
  9. #9
    B_Rad_NC's Avatar
    Mar 2007
    c
    25
    60
    thanks phypho, i understand that whole imaging thing now. These speakers actually have a very good amount of bass when mounted in the rear dashboard/deck/whatever. But none to speak of in the front, which is why i was confused. The HU i have ***** which im gonna upgrade soon, and i may get a small 4ch amp for all 4 component speakers. Im gonna take the dash out and remove some of the foam, and put the tweeters on the door at the top and see if that helps any. Thanks for the advice man
  10. #10
    CRXBMPN's Avatar
    CRXBMPN is offline ---> TEAM B.L.O. ME <---
    Jul 2004
    TigerTown, Maine
    32
    8,087
    45
    9 Post(s)
    the smartest thing you can do is get a deck that has 3x pre outs and get a 4ch amp for them, you will be amazed
  11. #11
    ThatChevyGuy's Avatar
    ThatChevyGuy is offline i heart Jager
    Jul 2006
    Arkansas
    11,799
    11 Post(s)
    yeah those speakers arent very good either.
    REFS:
    Squeak9798, Kumbos310w6, BigBangTheory, Jmanpc, MillzThaYungin, WLDock, -Leister-, ThomasG, J31Rob (and a few more I have forgotten)
    Quote Originally Posted by Spider Monkey View Post
    eat my asshole you insignificant bastard child of a retarded dingleberry cunt wrinkle fuck toy
    Quote Originally Posted by subzero View Post
    her pussy better be that nicest pussy you ever ever ever had. she better suck, swallow, jack off, eat ass and snatch, make sammiwich, do yard work and fix the vehicals while nude. Because a bitch like that is definately gonna cause alot of stress in your life, even thou she keeps your wallet and your balls drained.
    Quote Originally Posted by 05fronty View Post
    bitch you better swallow and not make a mess
  12. #12
    dftnz7's Avatar
    dftnz7 is offline ^F o r u m Boner^
    Mar 2008
    NE Illinois
    474
    You will get some serious reflection as well off the windshield which isn't helping....
    2004.5 Dodge Ram 2500 Quad Cab 4x4 HO Cummins
    880PRS / NINe.5 / Vifa XT25 / Seas CA18RNX / SSA Icon 12"
  13. #13
    PaulD's Avatar
    Apr 2008
    la la land
    701
    you have to learn to account for the reflections .... the best way is to install the speakers in such a way that you cannot hear any of the direct sound from the speakers, the result will be listening to what amounts to an imaginary speaker mounted where the reflection is coming from.
