Results 1 to 4 of 4
Reload Thread: Crutchfield
    smokeoff's Avatar
    smokeoff is offline here's my 3 cents
    Apr 2002
    Cambria,WI
    27
    1,115
    Crutchfield
    On their site I went to the what fits my car section. They have the adapter ring to convert 6x8 to 5.25" But they say the polk ex3 won't fit. Is this because it is too deep or is it because the screw holes don't match up wich I could fix simply by drilling my own.
    1997 Ford taurus Gl sedan
    HELP PLEASE.
    Randy Savage's Avatar
    Oct 2002
    New York
    28
    21,083
    4 Post(s)
    The plates on Crutchfield are pieces of ****, you are better off taking some plywood and making your own adaptor. Just measure off the mounting depth in your door to see if the woofer will fit.
    smokeoff's Avatar
    Apr 2002
    Cambria,WI
    27
    1,115
    About how thick should the plywood be
    Oct 2002
    New York
    28
    21,083
    4 Post(s)
    Well, that depends. If the woofer isn't going to fit because of the mounting depth, you should use a little thicker wood so it will have the clearance after it's mounted. If it will clear that back fine, then you can use like 1/4" or so.
