Results 1 to 6 of 6
Reload Thread: speakers for Honda Civic
    ledzep59's Avatar
    ledzep59 is offline Junior Member
    Jan 2008
    Powder Springs,GA
    Need suggestion on speakers for Honda Civic Coupe 2006. Speakers need to be shallow for the doors. I have heard Hertz Air, Boston Acoustics Pro, Dynaudio. The Hertz Air are fantastic but very expensive. Aline different series.
    Other items going in:
    HU: Alpine CDA9897
    Amps: possible Alpine PDX series, here again need to mount in trunk on back left
    corner. So they need to be small but efficent
    Any and all suggestions welcomed.
    thanks
    lostdaytomorrow's Avatar
    lostdaytomorrow is offline CarAudio.com Elite
    Oct 2006
    Loc
    1,569
    Re: speakers for Honda Civic
    They don't need to be real shallow for the front doors. There's plenty of room after you make a baffle.
    The rear deck on the other hand, definitely needs to be shallow if you were planning on running coax's back there.
    How much money are you willing to spend and what kind of amp to do you want to get?
    References: Vitveet x2, massiveaudiocw, n00b, darren700, Beerdrnkr, brchd, Mr. C, Raamaudio, h8ter, cman9012, Millertime1028, Teamsubgopoof, ABSOLUTEAUDIO, DB_DRAG_SPL, ls2poweredgoat, RyanM923, Worstenemy453, Connersdad19, pickup1, wgsj_fortvalley, ellocojorge
    BEAVER.989's Avatar
    BEAVER.989 is offline CarAudio.com Elite
    Apr 2006
    Michigan
    779
    The 9887 gives you the ability to go active. You can put together a really nice set of active comps for about $200.
    Alpine CDA-9887 - PG Xenon 100.4 - PG Xenon 600.1 - IDQ10V3(1.3cft. @ 28hz) - Polk SR6501 mids - Seas Neo's - Knuconceptz - RAAMAudio
    Common sense is far from common.
    ledzep59's Avatar
    Jan 2008
    Powder Springs,GA
    I was thinking of just running a front stage and not have any speakers in the back.
    Budget is open but I want to limit spending to about $1500 for speakers, amp and sub. I am looking for good sounding speakers. i.e. ones that are very detailed. My music is 98% jazz. I also thought about going active and getting speakers from Madisound. The doors will be deadened. As for amps, the Alpine PDX line, due to their small size.
    Oct 2006
    Loc
    1,569
    If your HU lets you go active, then definitely go active. Check out diymobileaudio.com for more information on going active.
    BEAVER.989's Avatar
    Apr 2006
    Michigan
    779
    Seas CA18RNX...$130/set
    Seas Neo's........$50/set
    PDX 4.150.........$430(can prolly find a better deal, though)
    PDX 1.600.........$330(same as above)
    This leaves $560+/- for a sub, box, wiring and deadening. Easily doable and a helluva nice package.
