Results 1 to 2 of 2
Reload Thread: What to do
    ace_800's Avatar
    ace_800 is offline CarAudio.com Veteran
    May 2004
    Okinawa, Japan
    37
    5,420
    4 Post(s)
    502 Post(s)
    What to do
    I'm running a set of Boston Pro60's off a PG200.4. Currently the rear speakers are fk'd and I trying to decide if I should just bridge the fronts to push ~200rms+ to the Pros or just find another set of rear speakers or run the Pros active.
    I've never run a set active though, so any opinons would help.
    Current set up: 94 Toyota Chaser (1JZ motor) Kenwood 5907, 3 way active (Alpine DLX-Z30T Tweets, CDT 04's and 06's), Helix P Six DSP/Amp, 4 IDQ12's, MMATS D3000.1
    66 Pontiac GTO, modified stock radio, Crossfire CFA 302, Kicker KS6.2's in the front kicks, Crossfire CFA 452 for the 6x9's I need.
    May 2004
    Dramaville
    19,653
    Re: What to do
    Try bridging the amp first. If you dont like that, try adding the rear fill. If you dont like that, buy the equipments needed to run them active.
