Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Reload Thread: Need a nice component system for a truck.
    Trepkos's Avatar
    Trepkos is offline CarAudio.com Elite
    Jun 2007
    Mississippi
    708
    I'm thinking a decent two-channel amplifier to power a set of components in each door.
    The speaker slot in the door is 6x8 size but I am willing to cut into the panel to place the midbass and the tweeter. I am also interested in a 4-Channel amp, two component sets setup if its ideal for my vehicle.
    So any recommendation on which setup I should go for?
    4-Channel Amplifier
    2x Component speaker set
    2-Channel Amplifier
    Component set
    Recommendations for which amplifier and component set I should get? And if I do op for cutting into the door panel, what could I do to hide or cover up the neglected speaker slot in the door?
    Trepkos's Avatar
    Jun 2007
    Mississippi
    708
    Re: Need a nice component system for a truck.
    Tellz mees, I giv free candies!!
    tbasile1's Avatar
    tbasile1 is offline CarAudio.com Elite
    May 2007
    Buffalo, NY
    1,169
    Do you have a substage, or plan on it?
    If so, comps in the back is kinda waste of money, if you want to do rears, just get some coaxials
    Heres what you can do, get a nice 6.5 component set and amp them, and run rears off the HU, or just get a nice comp set and forget about the rears
    And how much do you want to spend??
    EDIT: and to fit a 6.5 in a 6x8 location, just make a baffle out of some MDF so you can mount the 6.5
    REFS:
    sold to "Benilson09"
    DejaWiz's Avatar
    DejaWiz is online now Speaker Bee-otch
    Aug 2006
    Omaha
    5,169
    Fronts only with some kind of sub stage. Sub stage doesn't have to be wild by any means.. heck, even a little 8" sub in a small sealed enclosure off a 100w rms amp would provide more impact than a second set of midrange and tweeters mounted in the rear.
    2011 Kia Optima EX
    Factory HU + Speakers
    Planning:
    Front Comps - Blaupunkt Vc660 | Sub - Infinity Kappa 800w IB
    5ch Amp - still deciding
    References
    Bought from: jacobcopeland87, 95bat, alxmlr789, na_rsx
    Trepkos's Avatar
    Jun 2007
    Mississippi
    708
    Quote Originally Posted by DejaWiz View Post
    I have two 12" CVT's behind the seat for the substage.
    I was looking at the following component set....
    Phoenix Gold RSd65cs 6-1/2" 120W Component Speaker System
    http://tinyurl.com/2uoz6a
    Now to find a matching 2-Channel Amplifier.
    DejaWiz's Avatar
    Aug 2006
    Omaha
    5,169
    Quote Originally Posted by Trepkos View Post
    Lots of positive reviews out there for that comp set, so good choice. Try to find an amp that does at least 2x120w rms if not upwards of 2x160-200w rms. Those RSd's will soak it up and the results should be fabulous.
    2011 Kia Optima EX
    Planning:
    References
    tbasile1's Avatar
    May 2007
    Buffalo, NY
    1,169
    Thats a really nice comp set
    I think we've recommended this amp to others with those PGs
    http://www.millionbuy.com/prfap1000.html
    Just set the gains right and you should be fine!!
    REFS:
    DejaWiz's Avatar
    Aug 2006
    Omaha
    5,169
    ^ very decent budget amps.
    To give those comps 120w rms per channel, the amp's output voltage would be 21.9V, measures with a DMM and test tone playback.
    SQRT(WATTS * OHMS) = OUTPUT VOLTAGE
    SQRT(120 * 4) = 21.9V
    If you are going to set the gains yourself and not already familiar with the procedure, please read the sticky here and/or click the link in my sig.
    2011 Kia Optima EX
    Planning:
    References
  9. #9
    genxx's Avatar
    genxx is offline Team JL Audio
    Mar 2007
    Oklahoma
    1,170
    X3-On this set-up. The PG Rsd are impressive for the price and that profile is an excellent budget amp. The amp will allow you plenty of headroom and the PG rsd like a little pwr. Great recommendations on this set-up.
    2009 USACi Basic Consumer World Champion, '09 IASCA INAC 2nd Place, 2010 MECA Finals MODEX 4th, '10 OK MODEX State Champion--Addicted to Sound Quality
    '06 F250: JL-Zapco-Pioneer
    '08 Focus-Kenwood-Zapco-ID-Hertz
    Team JL Audio, Team RAAMmat, Team Advantage Audio, Team MSE, Team Zapco
  10. #10
    dwynne's Avatar
    dwynne is offline Member
    Jul 2007
    TN
    35
    Quote Originally Posted by Tbayz1 View Post
    What about spending $5 more and getting the AP1040 4 channel. You could bridge it (assuming the components are 4 ohms) and get the same power out. Add an active x-over now or later and run without the passive for better sound? It would not get as loud as it would run passive with the AP1000 2 channel, but it might be loud enough, not much more expensive, and sound better?
    http://www.millionbuy.com/prfap1040.html
    Dennis
  11. #11
    Trepkos's Avatar
    Jun 2007
    Mississippi
    708
    Quote Originally Posted by dwynne View Post
    Dennis
    Cool. tell me more about this.
  12. #12
    dwynne's Avatar
    Jul 2007
    TN
    35
    A technical explanation, but does have diagrams:
    http://sound.westhost.com/biamp-vs-passive.htm
    http://sound.westhost.com/bi-amp.htm
    Also here: http://www.rocketroberts.com/techart/multi_amp.htm
    You have a sub and amp now, right? You could buy the 4 channel amp now and bridge it to two channel and (in theory) have the same power into 4 ohms as the 2 channel amp - for $5 more and 1/2" wider or so amp. Doing it this way or with the 2 channel amp means you have to find a place to mount/hide the passive crossovers (the boxes you see in the picture with the mids and tweeters).
    You could then buy an active crossover or a nice head unit (Eclipse?) that does bi-amp with sub out (or tri-amp). You do not use the passive crossovers, but you run the signal from the head unit into the active crossover (or use the built in active i nthe head unit) and then feed mids signal to 2 channels of the 4 channel amp and the tweeter signal to the other 2 channels. You only have to mount/hide the active crossover (if used) and not the 2 passive ones that came with the speakers.
    The downside is that with 2 channels you get 2x the power as you do running 4 channels, but you are (potentially) making life easier on the amp having to drive just the one speaker per channel directly. Just like when you add a sub and sub amp - all it has to do is produce the low frequencies and having a high pass in your front speakers means the speakers and the amp does not have to try to reproduce the lows. Makes the speakers happy and the amps happy.
    Also you have gain controls for the tweets and the mids both on the active crossover and on the amps input so you have a lot more control of the balance of the two speakers. Some passive crossovers may have pad resistors in them to get the levels to balance, and these waste power. The coils in the passive crossovers also waste power.
    If you got the 4 channel then you could hook it up direct to the mids only with 2 channels in 4 channel mode (not bridged) and see how it played (don't try it with the tweets). If you have no trouble driving them with 2 channels, then get an active crossover and bi-amp. If they just will not get loud enough to suit you with clean power, then bride the amp to 2 channels and use the passive crossovers than came with the speakers. You will have wasted $5, I guess.
    I am sure if I screwed something up, one of the pros here will straighten me out
    Dennis
  13. #13
    Trepkos's Avatar
    Jun 2007
    Mississippi
    708
    This is my current "plan to buy" headunit:
    Kenwood eXcelon KDC-X791
    URL: http://tinyurl.com/2mc9wd
    Thanks for the information dwynne though it kinda confused. But you were basically speaking of running the tweeters and mids through different channels on a 4-channel amplifier using an active crossover and whatnot, am I correct?
    Also, what are some examples of active crossovers?
    Also if you have an IM service we could perhaps discuss this more indepth there.
    But I was thinking of an idea to have a four channel amplifier powering two different component sets or even two of the same.
  14. #14
    AcidicDreams's Avatar
    AcidicDreams is offline I don't need one of these
    Jan 2005
    Auburn WA
    35
    3,965
    More is not better, you only need front comps...
    remember, Stereo, two channels..
    not to mention it's a single cab pickup...
    Driving a 2003 Lexus GS430 and a 1996 Lexus LS400
    GS430 - Massive RK Tweets/Crossovers + Phass MW650 NEO Mids, JBL GTO 755.6 amp, IDQ12v2 in 1cu ft sealed substage
    Refs: CA.com - excelerater, fosgate140, 99StangGt, desertheat, Frito, digital mint, dkguitarist, BoominBeast (didn't scam me), Fast1one, shiipseki, newtitan, Scoobydoo, spudracer326, sr_se-r, redlinese-r, James Bang, tweet02, effenay, and Mike Dressure ::: ECA - BBOYSTEVIE, Need-SQ ::: DIYMA - macxx, Kuztimrodder (very happy), and azngotskills
  15. #15
    Trepkos's Avatar
    Jun 2007
    Mississippi
    708
    Quote Originally Posted by AcidicDreams View Post
    Yay! Ok
