Results 1 to 8 of 8
Reload Thread: Germanium Crossover
    theputz's Avatar
    theputz is offline Member
    Jul 2007
    canada
    48
    Germanium Crossover
    I plan on running a 2 way active set up ( and by this i mean running the mids on their own L/R channels on a 4 channel amp and the tweets on the another L/R channels on the same amp) if i do it this way do i even need the crossovers? Doesnt the crossover in the deck replace that. Can you buy the speakes with out it? The crossover they come with is suppose to be bi amp capable. What does that mean?
    THanks
    DejaWiz's Avatar
    DejaWiz is offline Speaker Bee-otch
    Aug 2006
    Omaha
    5,173
    Re: Germanium Crossover
    Biamp means that you can run 2 channels of the amp into the MID IN of the passive xovers and 2 channels o the amp into the TWEETER IN of the passive crossovers. The passive xovers will still do the job of properly crossing the frequencies.
    If you run a true active setup (either from an active capable HU or an aftermarket active xover, it will take care of crossing the frequencies before the amplifier does it's job.
    BIAMPING:
    HU RCA's -> AMP INPUTS
    CHANNELS 1 and 2 OUT -> PASSIVE XOVER TWEETER IN
    CHANNEL 3 and 4 OUT -> PASSIVE XOVER MID IN
    PASSIVE XOVER MID OUT -> MID
    PASSIVE XOVER TWEETER OUT -> TWEETER
    ACTIVE:
    HU RCA's -> ACTIVE XO (if needed)
    ACTIVE XO (or HU) RCA's -> AMP INPUTS
    CHANNELS 1 and 2 OUT -> TWEETERS (or mids, depending on the wiring)
    CHANNELS 3 and 4 OUT -> MIDS (or tweeters, depending on the wiring)
    2010 Kia Forte SX
    2009 Kia Borrego EX 4x4
    Setting Amp Gains:
    http://s13.zetaboards.com/Den_of_Dragons/topic/508709/1/
    References
    Bought from: jacobcopeland87, 95bat, alxmlr789, na_rsx
    theputz's Avatar
    Jul 2007
    canada
    48
    what would be the advantage of bi amping?
    DejaWiz's Avatar
    Aug 2006
    Omaha
    5,173
    Quote Originally Posted by theputz View Post
    One advantage is it gives you control over how much power the pairs of mids and tweeters receive individually.
    2010 Kia Forte SX
    Setting Amp Gains:
    References
    theputz's Avatar
    Jul 2007
    canada
    48
    buy an active setup gives your crossover control therefore more superior set up correct?
    DejaWiz's Avatar
    Aug 2006
    Omaha
    5,173
    Not necessarily. Those Germanium crossovers are engineered to match up with those mids and tweeters to the T.
    However an active setup will allow you to change things like the crossover points which might help you tune and adjust to your specific preferences.
    2010 Kia Forte SX
    Setting Amp Gains:
    References
    theputz's Avatar
    Jul 2007
    canada
    48
    specific prefrences and enviroment. They may be engineered to the t but all the engineering in the world wont tell you what enclosure they will end up in.
    DejaWiz's Avatar
    Aug 2006
    Omaha
    5,173
    And you are absolutely correct in that regard.
    2010 Kia Forte SX
    Setting Amp Gains:
    References
