Results 1 to 8 of 8
Reload Thread: Thermal Damage From Clipping?
    dirthog's Avatar
    dirthog is offline Uh What?
    Nov 2006
    Oregon, IL
    112
    How noticable is thermal damage caused by clipping?
    Pioneer DEH-P880PRS
    Front: Polk Audio SR6500
    Amp: Alpine MRV-F545
    Sub: Polk Audio SR124DVC
    Amp: Alpine MRD-M1005
    DejaWiz's Avatar
    DejaWiz is offline Speaker Bee-otch
    Aug 2006
    Omaha
    5,173
    Re: Thermal Damage From Clipping?
    Depends on the severity of the clipping and how much the amplifier is overdriving the speakers.
    http://en.wikipedia.org/wiki/Clipping_%28audio%29
    2010 Kia Forte SX
    2009 Kia Borrego EX 4x4
    Setting Amp Gains:
    http://s13.zetaboards.com/Den_of_Dragons/topic/508709/1/
    References
    Bought from: jacobcopeland87, 95bat, alxmlr789, na_rsx
    bdawson72's Avatar
    bdawson72 is offline Finally Has Bass Again
    Nov 2005
    434/804, Virginia 15's:Yezzir
    25
    17,568
    It can be pretty bad actually
    149@32 hz(headrest)......Dammit i needs to be louder
    Decipha's Avatar
    Decipha is offline MurdaCapital.com
    Mar 2005
    New Orleans, LA
    25
    3,275
    x2 i have a set of boston nx87s i decided to throw on my orion 8004 for shiits and giggles... you could say i burnt up the speaker, the little cap died first though
    supercoupe enthusiast x9
    pioneer h/u
    boston z6 comp set
    orion 400x2@4 rms
    2x re xxx 15s
    orion 2500d@1
    3cu ft^3 @ 38hz /sub
    DejaWiz's Avatar
    Aug 2006
    Omaha
    5,173
    Quote Originally Posted by Jmac View Post
    What a terrible wiki ... By far the worst explanation of clipping I've seen in my life ...
    As for how noticable the thermal damage is, it's the same as when you exceed the thermal limits of the speaker with a clean signal.
    It's Wiki... edit it for accuracy if you feel it's sub-par. Or provide a better source please.
    2010 Kia Forte SX
    Setting Amp Gains:
    References
    Gary S's Avatar
    Gary S is offline CarAudio.com Elite
    May 2006
    Ex JL Audio Rep
    1,072
    How noticeable is it? I guess it depends on the extent of the damage... some speakers won't play if they get too hot and that heat causes severe damage.
    Kind of like a car I guess... if the A/C breaks, you can still drive it but it's not as much fun. But if your car breaks down and you have to hoof it, you are really going to hate your car.
    Clipping does not matter... it's how hot your speaker/coils get... you can heat up a speaker, clipping or not. But I will say you are more likely to get it hotter with clipping. But it is not the end-all be-all of speaker damage.
    If I hold a lighter under your boo-boo for three minutes (moderate power clipping over time), or hit you with a flamethrower (mondo musical peak), either way, it's still going to leave a mark. Would you like to be burnt to a crisp quick or slow-cooked?! Do you smell what I'm cooking?!
    For Sale
    Kicker C15C-4 Competition 15" 4-ohm subwoofer, new in box, old stock
    Soundstream Reference 405 5-channel amplifier
    (2) Parts Express DVC12 12 inch subwoofers
    Send a private message to me for more details on these products.
    Apr 2007
    Newton, IA
    43
    We made some videos and had some fun.
    Some people tried claiming the class D and class AB clipping signals not only look different, but kill a coil in different ways.
    They both overheat a coil the exact same way when clipping.
    We took a coil rated at 400 watts and put 700 watts of clean tones into it. It took quite some time to overheat the voice coil, but eventually it was gone.
    Then took the rated 400 watts and started to dirty up the signal. Overheated the coil in 1/3 the time.
    We then took a 200 watt signal and clipped it all to hell. It went very fast.
    So does clipping damage a speaker, yes...how fast...it depends on the severity of the clipping.
    dirthog's Avatar
    Nov 2006
    Oregon, IL
    112
    So is there any way to find out if there is minor damage? Or if there is it would be noticable?
    Pioneer DEH-P880PRS
