Results 1 to 5 of 5
Reload Thread: Focal 130v2's rated at 70rms are taking 150rms and loving it
    ninjatek's Avatar
    ninjatek is offline Ninja Member
    Jun 2006
    Columbia, IL (St. Louis)
    106
    I orded a 3way set of Hertz components (High Energy), and I do have an active thread on it.. They are supposed to be in tomorrow, so I went ahead and began prepping my car.. Previous setup (what i just changed) was that I was pushing focal components up front and kappa 6x9's in back with a 4x70rms alpine amp. The kappas can handle more power and are more effecient, so at equal fade my image was almost completely from the rear of the car... My plan was to buy a set of components that could handle the power of that amp in bridged mode, 200x2rms instead of 70x4rms.. and also run the kappas off the head unit for rear fill..
    So I ran the speaker wire from the HU to the kappas and got that done.. They aren't nearly as loud as they were off the alpine amp. but w/e I loose in that I expect to gain by utilizing the amp bridged to the front stage alone..
    So I bridged the amp and hooked up my focals... I'm pulling them out tomorrow, so I decided to experiment with how the focals liked the almost triple power... They went from 70x2 to 200x2. With the gain on the amp at mid (nominal), I must say that the focals are loving the power. They are supposedly rated at 70rms, which is what I was giving them, but I've been able to crank it (63/80) on the HU without any distortion.
    I feel kinda stupid for not running it this way in the past, but I didnt think they could handle it.. Just by doing what I did, and not even adding the new components, I've corrected my soundstage and gotten more volume. If I would have known I could have done this all along, I'm might not have even bought a new set. I love the focals..
    I must say, it seems that the extra power didn't so much add a bunch of volume, but my midbass is alot richer and they do have extra punch. They are louder too, but as I said, they made impressive gains in midbass...
    bla... early morning rant
    (TOTALED!!!)2000 Accord EX Coupe
    2" Drop
    18" Motegi M7 Gunmetal (coming soon)
    Ninja Body Kit
    Eclipse 8445
    Lightning Audio 2000Watt AMP Kit
    Alpine MRP-F450 100x4rms
    Alpine MRP-M650 600x1rms
    Focal Polyglass 130 Components
    Infinity Kappa 6x9's
    Q-Logic Kick Panels
    3x10 Infinity Perfect DVC Subs
    Custom Fitted Fiberglass Sub Box
    I'm now driving a z4.. will update sig soon..
    ani's Avatar
    ani
    ani is offline Member
    Mar 2007
    77
    Re: Focal 130v2's rated at 70rms are taking 150rms and loving it
    Were they running on full pass or HPF ?
    The reason I ask is because if they were fed extra juice for extended periods of time chances are you would have encountered some damage due to the low bass hits now and then.
    ninjatek's Avatar
    Jun 2006
    106
    high passed at 100
    2" Drop
    Ninja Body Kit
    Eclipse 8445
    Q-Logic Kick Panels
    ani's Avatar
    ani
    Mar 2007
    77
    Ok thanks... Are you upgrading to the Hertz ESK165 ? Any particular reason your dropping the Focals? Or is it just the higher rating on the hertz.
    joelb's Avatar
    joelb is offline Member
    Mar 2007
    Northern Virginia
    100
    I have the Focal 130 CV1s on a Boston GT-22 @ 2 ohm stereo (135RMS @ 12.6 v.. 160@14.4 so each speaker was geting 70-80 RMS) and Highpass x-over at 75Hz... subwoofers lowpass at 80 Hz...
    They are amazing and will take the power. The Polyglass 2's (130v2) can take more power with ease, like you are seeing.
    What is your subwoofer lowpass x-over going to be set to? You need to have some overlap.... but dont go too high with the lowpass, because you will be able to locate the bass in the rear...
    You will also notice a difference with a Class A/B amp on your components.
    Just be careful with that much power and extended periods of playing at high volumes, since that is when you can blow the speakers
    HTH
    joelb
