Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Reload Thread: need advice
    patrick1202's Avatar
    patrick1202 is offline CarAudio.com Veteran
    Dec 2005
    gallatin,TN
    27
    3,191
    need advice
    ok so im slowly working on my car audio and starting out with my mid's and highs first and then movin to the bass (subs and huge **s amps) but right now i need some advice ok here it goes i just recently got a kenwood kdc-mp4032 for my hu thats my start lol and after i got two pioneer premier coaxial 4 way 6x9's (for reardeck already installed) ok here comes were i need the advice should i go ahead and get an amp for the 6x9's and leave the stock front door speakers or wait on the amp get the front door speakers and run it off the hu?? or any other adive or suggestions you all have let me know and if you need any more info to help just ask ill try my best to answer oh and if it helps my 6x9's are 80 watts rms at 4 ohm so yea please help and it's in a 1993 concorde
    Dec 2005
    gallatin,TN
    27
    3,191
    Re: need advice
    and what should i have my hpf and lpf on with the set up i have right now and whats the diff in the higher the number and the lower the number on each one im a lil confused on it
    Dec 2005
    gallatin,TN
    27
    3,191
    Re: need advice
    any body lol??? because i can get a 60x2 rms amp tommorrow for 40 if thats what i should do
    XanderMoser's Avatar
    XanderMoser is offline Poor college student
    Mar 2007
    Wisconsin
    573
    Re: need advice
    I would get the front speakers first. Then get a 4 channel amp for the entire system.
    The high pass and low pass filters are explained in the stickies. High pass filters block low frequencies, letting higher frequencies pass. I would set these at 80 Hz on your head unit...but maybe after you get a sub. For now, put it as low as possible. Unless you are bottoming out your speakers, then raise that up. The low pass filter should be all the way up, there is no need to block high frequencies since all your speakers are full range.
    Someone please correct me if I'm wrong
    DaveDSMer's Avatar
    DaveDSMer is offline Senior VIP Member
    Oct 2006
    Augusta, Georgia
    449
    Re: need advice
    I would not amp the rear coaxials if the front are stock with no amp. All of your strong music would be coming from the rear and would destory all staging.
    1988 Ford Ranger Supercab:
    Headunit: Kenwood EZ700SR
    Front Stage: SoundStream EXC4.1 Components
    Rear Fill: JBL GTO8626 6x8
    Hi Amp: Blaupunkt PCA460 60x4 rms
    Sub: Infinity Perfect 12.1
    Box: 1.3ft Sealed
    Sub Amp: Sony XM-D1000P5 500x1 @4ohm rms
    Dec 2005
    gallatin,TN
    27
    3,191
    Re: need advice
    ok so right now i got 40 somethin dollars should i go ahead and get the front door speakers there like 39 dolllars then get amp 40 dollars then get wiring will it make a big diff with the aftermarket speakers in the front im thinking about getting the pioneer premier 3 way coaxial for the front since i got the pioneers in the back
    CobaltKicker's Avatar
    CobaltKicker is offline I Humped Your MOM
    Mar 2007
    Orlando, FL
    759
    Re: need advice
    ya
    2006 Chevy Cobalt LT
    Kenwood KDC-MP832U Headunit
    Memphis EQ4 Equalizer/Line-Driver
    Infinity Kappa Components and Coaxials
    Kicker 0612L7 Subwoofer
    Hifonics Brutus 1206D Sub Amplifier
    Kicker Interconnects
    Rockford Fosgate Comp 150 AMP Fuse/Holder
    Box @ 2.5 cu. ft. tuned to 35 hz
    My Blog: http://CarAudioOrlando.blogspot.com
    My Box: http://www.caraudio.com/forum/showthread.php?t=224784
    References on CarAudio.com: jcee, Immacomputer
    Dec 2005
    gallatin,TN
    27
    3,191
    Re: need advice
    well if i do get the front speakers THEN the amp tell me if this would be good ok the amp is 60x2(4ohm) which is also my speakers and the 6x9's are 80 rms 4 ohm and im pretty sure the fronts would be like 35-40 rms 4 ohm so would a 2x60 4 ohm amp be good my two 6x9's in one channel and fronts in the other channel if not advice it's an amp my friend has and he needs money and i need an amp so yea it would be helpin us both out but i dint wanna get it if it's not gonna make a big diff
  9. #9
    Dec 2005
    gallatin,TN
    27
    3,191
    Re: need advice
  10. #10
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    Re: need advice
    It's not a crime to use punctuation, you know.
  11. #11
    Dec 2005
    gallatin,TN
    27
    3,191
    Re: need advice
    Yea, i know i do that sometimes. I forget, but yea it would **** if it was against the law i would be in the pin.
    jk oh and sorry bout the double post
  12. #12
    Mar 2007
    Wisconsin
    573
    Re: need advice
    After you get your front speakers, then you need a 4 channel amp. Not a 2 channel. 4 speakers to power = 4 channel amp. Try to get an amp with an RMS wattage rating of the same or greater than (but not like 3 times as much) your biggest speakers.
  13. #13
    DaveDSMer's Avatar
    Oct 2006
    Augusta, Georgia
    449
    Re: need advice
    if you ran one channel to the front and one channel to the rear with a 2 channel amp... it would sound terrible. You would lose all stereo sound as there would no longer be any left or right.
    Box: 1.3ft Sealed
  14. #14
    DaveDSMer's Avatar
    Oct 2006
    Augusta, Georgia
    449
    Re: need advice
    it would be best for you to use that 2 channel amp on just the front speakers and leave the rear on the HU until you can afford a 4 channel amp.
    Box: 1.3ft Sealed
  15. #15
    Dec 2005
    gallatin,TN
    27
    3,191
    Re: need advice
    yea so i went ahead and bought the amp because my friend really needed the money and so im gonna get some more money get the front speakers and the wiring for the amp and run it to the fronts and do the back so yea and i got a q i got a 1993 concorde and it's pretty long do you think a 18ft rca will work
