Results 1 to 7 of 7
Reload Thread: Tru 4.65 bridged (no rear fill)
    Pl8er's Avatar
    Pl8er is offline Can you solve it?
    Dec 2001
    Columbus, OH
    37
    4,894
    2 Post(s)
    So currently I am running ascendant 6.5's for rear fill and they are "ok" and I am running CDT cl-61's as my front comps. My thought was to bridge my tru 4.65 and run only the fronts. What does everything think? Would this destroy the speakers? I had the amp benched while getting the BB upgrade and was told its running around 80 RMS per channel. So I would guess 140-150 watts would be going to the CDT's if I bridged it.
    Also, I plan on trying to go active at some point and getting rid of the rear fill completly, what would you guys suggest? Should I use the polyfill's as my mid's and buy a new pair of tweeters? Or should I get new for the front? I'm running a RF symmetry, so don't think going active would be very difficult at all.
    Thanks.
    NEVER buy from Dealer Cost Car Audio, ask me why
    Rainbow SLC+Tru 4.65 + RF 3sixty.2 = yum.
    Quote Originally Posted by IamDeMan View Post
    Draw away. It has already been proven with math that you are wrong. I believe math is > paint last time I checked.
    "5 midgets spanking a naked man covered in thousand island dressing, is this love too?"
    Quote Originally Posted by pitbull187 View Post
    FYI the blue wire was connected to something else. I know it was put in right b/c the guys at Circuit City put it in.
    "We never underestimate, the destructive power of change."
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Re: Tru 4.65 bridged (no rear fill)
    Quote Originally Posted by Pl8er View Post
    Go for it...see what you think.
    Not inherently. Just use your head and decrease the gain/attenuation as needed to avoid overpowering them if they begin to sound stressed.
    Depends on your budget
    I presume you mean the Ascendant Poly's.....in which case; sure.
    Meh...I'd try the Poly's first. Why? Because you already have them No point in spending more money if something you already have might make you happy.
    azngotskills's Avatar
    azngotskills is offline CarAudio.com Elite
    Dec 2005
    Dallas, TX
    1,834
    I personally like my car w/o rear fill, but I have a small hatchback...its really personal opinion. I would try out the AA Poly mids w/ the CDT tweet or one of your choice and run active if you decide to. Just try it out
    2000 Toyota Celica
    ***under construction***
    References:
    6spdcoupe / belunt / SPL140.2 / Loud3 / JoeHemi57 / Megalomaniac / gordos420 / Remus33 / nVRuckus / alann / jdrockafella / gundecker / brypink / QTRHORSE / boostdfoci / foreman / Duke / James Bang / 00maxima / stuckinok / Benilson09 / jester6435 / BLD 25 / jacka / datboiroy / jorginho / bk12321 / meh / OldOneEye ....more to come
    Pl8er's Avatar
    Dec 2001
    Columbus, OH
    37
    4,894
    2 Post(s)
    Hey there! Thanks for the replies. I guess part of my confusion is using the pre-amp instead of the amps. I do not use the gains on my amp at all. I'll bridge it and give it a try but my pre-amp is set to 231-250 on the display, I will go back through the auto gain setting on the unit again to see what I can do.
    Do you agree that active should be fairly simple using the RF Symmetry?
    Also, budget wise, I would want to spend around 500-600 on a new set of fronts if I bought them. I guess I just don't want to rip the door off and install if its not going to sound good.
    Dodge Stratus R/T is a pain to remove the door and get everything to line back up.
    Dec 2005
    Dallas, TX
    1,834
    I think if you went active with a $500 budget for the frontstage, the potential for great sound is there but it will be dependent on install and tuning ability. Going active is a full out thing though, its not going to be a drop in replacement.
    2000 Toyota Celica
    References:
    Pl8er's Avatar
    Dec 2001
    Columbus, OH
    37
    4,894
    2 Post(s)
    I guess I'm confused to the complexity of going active. I thought that it was basically setting the frequencies per each speaker that they are capable of? Then finding a place where you want a slight overlap of the one speaker to the other. With the symmetry, its basically just typing in the numbers you want for lowpass and highpass cutoff and you can set each one independantly.
    squeak9798's Avatar
    Jun 2004
    USA
    26,300
    While this "sounds" like an easy task (no pun intended)....finding the optimal crossover frequency and slope for your specific speakers, vehicle and installation along with proper level matching can prove to be much more challenging than one might think. While it would be pretty easy to make it sound "decent"....it is MUCH more challenging to make it sound GREAT by finding the best combination of xover point/slope and proper level matching and equalization (making all of the $$ and time well worth the effort)....especially if you are trying to do it without the use of something like an RTA.
    If you can't differentiate between "good" and "great" stereos; then I wouldn't waste my time going active and just find a good modest pre-built comp set. That doesn't mean your deaf or stupid; Just that the benefits might not be worth the time and money, when a more cost and time effective alternative exists that would suit your needs just aswell. Not everybody has the same goals in mind.....and you need to figure out what best suits you.
    With $500 you can build a very good active frontstage with proper tuning. Spend some time over at http://www.diymobileaudio.com/forum/index.php? and http://forum.elitecaraudio.com/forum....php?forumid=2 researching drivers. There is so much to choose from it's very easy to get overwhelmed with the "simple" task of finding the best drivers for your taste and preference.
    As far as how "simple" it would be with the Symmetry.....I can't answer as I'm not familiar with it's actual functionality.
