Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
Reload Thread: 3-way active
    Kenny Pollock's Avatar
    Kenny Pollock is offline drag it!
    Aug 2005
    Hollywood, Florida Low: Yes
    22
    4,225
    3-way active
    Alright, just gonna be blunt and ask for what I need:
    I have a $300 MAX budget for everything.
    I'd like to go active, my goal is LOUD without sounding like ****.
    Let's say I can fit any size mid/tweeter in my car.
    I have a Pioneer Premier DEH-P880PRS... so if I need an additional component for the 3-way setup, then include that in the $300 budget.
    I have a Sundown Audio 100.4 to power this. Specs are as follows:
    CH1+2 : 10 - 100 Hz Subsonic
    CH1+2 : 50 - 5000 Hz HPF
    CH1+2 : 35 - 2500 Hz LPF
    CH3+4 : 10 - 100 Hz Subsonic
    CH3+4 : 50 - 5000 Hz LPF
    CH3+4 : 50 - 1000 Hz HPF
    12dB per octave crossovers
    CH1,2,3,4 : 35 - 120 Hz variable 0 - 18dB bass boost
    100 x 4 @ 4 ohms
    150 x 4 @ 2 ohms
    300 x 2 @ 4 ohms
    What do you recommend (links please)?
    Thanks in advance
    2006 Mercedes-Benz CLS55 AMG
    Supercharged V8 5.5L
    j3bus2k3's Avatar
    j3bus2k3 is offline Si vis pacem, para bellum
    Aug 2004
    St. Pete, FL
    6,285
    Re: 3-way active
    For a true 3-way active setup, your going to need 6-channels of amplification. What you can do is use channels 3&4 for your midbass drivers only and then 1&2 could be run to a passive crossover whereby it'll be split to your midrange and tweet.
    A simple 3-way crossover can be had from most companies; Kicker, Memphis, Coustic, to name the ones I've looked at.
    The most talked about midbasses I read about are the Dayton reference 7" and 8", ID CX64, AA Poly and Adire Extremi 6.8. You cant go wrong with either of those choices really.
    Midranges: Usually the dayton 2", vifa D75 or the Coustic Reference DR-304P.
    Tweets: Theres wayyy too many to list and link and my clickin finger is tired, lol. Dayton RS, Dayton DC25, Seas, vifa, scan speak, Morel, Rainbow Cal25...
    We can all speculate as to which speaker is the best of the bunch but they're all going to sound different in everyone's different install. It just comes down to what you like and what fits the budget...
    AIM: SPL Performance1
    /////Alpine 9835
    Active Processing via Coustic XM7
    Dayton 7" Mid-woofer with Seas Neo Tweet
    JBL/Crown 1100 & Power 300.4
    12" TC3000 Based Custom in 2.25ft^3 at 32hz
    Wallet say But I say
    References:Moe Lester, PV Audio, sss18734, DJ-Torn, dleccord, jiggy2dmax, Negativezeroz, Bama350z, TeamPSI, dB Dom, Kenny Pollock, Flossinon24s, Patfitz9 (x2), AppleBonker, BassAddictJ, the727kid, skadude016, CaliKid, Thumper88, Djman37, TeamQuakeCelica, Cerob, Pimpedout97x, Troy_Audi0, got_focus?, Karleon, Jamaica2G, rtillare, dumple, JohnnyBusa, mattmcss, whitem1ke88, nineball
    dalucifer's Avatar
    dalucifer is offline Not Minion Approved
    Oct 2005
    Los Angeles
    26
    2,571
    2 Post(s)
    Re: 3-way active
    i use AA poly mids..And vifa tweets..Set cost me around 120..Gets loud and sounds great..
    Aug 2005
    22
    4,225
    Re: 3-way active
    So I'm gonna pickup a Sundown 100.2 and have 6 channels at hand...
    Which crossover should I buy? http://www.partsexpress.com/webpage....up_ID=194&SO=2
    I wanted to go with AA Poly mids, but I've hard nothing but bad tinsel leads... not sure if I want to mess with them.
    dbornotdb's Avatar
    dbornotdb is offline Custom Fabricator
    May 2004
    Bradenton, FL
    1,491
    19
    Re: 3-way active
    So now you want to go with a 3-way set-up?
    And those crossovers you linked are passive crossovers.
    The bitter after-taste of a poor quality job will last far longer than
    the sweetness of that cheap price!
    Aug 2005
    22
    4,225
    Re: 3-way active
    I'm just getting a lot of conflicting information....
    Some say a 3-way setup will be just as loud as what we were planning, just sound better...
    I just want to do things right, and not have any problems I have to go back and fix. And I'm a n00b, sorry about the wrong crossover link.
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    Re: 3-way active
    Thats cool, a good 3 way will sound better than the 2 way, but more amps needed to do so.
    Like was mentioned earlier, you need an electric crossover.
    azngotskills's Avatar
    azngotskills is offline CarAudio.com Elite
    Dec 2005
    Dallas, TX
    1,835
    Re: 3-way active
    OK i will make it easy for you and give you what I would do. Here are the drivers:
    Tweeter: http://www.partsexpress.com/pe/pshow...number=275-130
    Midrange: http://www.partsexpress.com/pe/pshow...number=285-020
    Midbass: http://www.partsexpress.com/pe/pshow...number=295-376
    Each driver will have its own channel of amplification using the 100.4 and 100.2. You dont need and external crossover, just use your prs880 for crossing your tweet, mirdrange, and midbass drivers and you amp to low pass your subs. TA on the prs880 can only be used for the frontstage, but since lower frequencies are really localized justing adjusting phase should be ok.
    Front RCAs to tweeters, Rear RCAs to midrange, and Sub RCA to midbass and sub (you will need to split the RCAs using RCA y-splitters for this). HP tweets at ~4000hz, BP midrange ~4500k-600hz, BP or LP midbass ~500-63hz, and LP sub ~63hz using the amp crossovers . These are generic crossover points and you need to decide which crossovers frequencies and slopes are specifc for you and your car. The tuning process takes the longest and is the most tedious process in an active setup FYI. Hope this helps and clears any questions
    2000 Toyota Celica
    ***under construction***
    References:
    6spdcoupe / belunt / SPL140.2 / Loud3 / JoeHemi57 / Megalomaniac / gordos420 / Remus33 / nVRuckus / alann / jdrockafella / gundecker / brypink / QTRHORSE / boostdfoci / foreman / Duke / James Bang / 00maxima / stuckinok / Benilson09 / jester6435 / BLD 25 / jacka / datboiroy / jorginho / bk12321 / meh / OldOneEye ....more to come
  9. #9
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,737
    20
    Re: 3-way active
    Just stick with the 2way.
    A LOT less headaches.
    nG
    http://crunktimes.com/ct/
    nG - BSEE
  10. #10
    Aug 2005
    22
    4,225
    Re: 3-way active
    Thank you!
    I was talking to jntar and j3bus who both recommended the same exact Daytons, so I'm set with those.
    Thanks for the information bro!
  11. #11
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    9,602
    13 Post(s)
    Re: 3-way active
    I'm running 2 pair of the AA poly mids and have never had any tinsel lead slapping problems and I play them plenty loud. Mine are only about 6 months old, so maybe it was the first few runs of them.
    Aren't you going CRAZY with the subs? If so I'd personally recommend 2-4 pairs of REV coax's as I doubt KILLER SQ is your goal, so why hassle with comps and going active. REV's will get plenty loud and keep up with your subs and they do sound good...
  12. #12
    alphakenny1's Avatar
    alphakenny1 is offline LOTUS FTW!
    Jun 2005
    San Jose, CA
    30
    3,017
    Re: 3-way active
    to be honest stick with a 2 way front stage. much easier to tune and less on the wallet. i think honestly think with your goals, getting loud and still sound good, a good 2 way setup can do that well. the real advantages to a 3 way up front is staging and imaging also of course tonality. but a 3 way up front you would usually put the midranges in the kicks and hence decreasing the path length differences which is good for imaging. then with midranges in kicks, the speakers are physically farther away from you and hence a deeper stage. but if you just want to get loud and sound good without worrying too much the of staging and imaging, stick to a 2 way.
    W200/H701
    Dyn MW160/Lotus RM110/Seas Neo Alum/Idmax
    Alpine PDX
    References
    RoudyruffKK, mattmcss, BLD 25, 02corvette
    bjfish11 ,slain93gsr, DJGTSR, flakko, FoxPro5
    2.2l integra, rawdogj, guy022077, bumpn_gt
    lowlinc, rocky 59, alann, ECA, DIYMA
    bay area people need some custom work done? pm me. here's some work that we've done:
    http://www.cardomain.com/ride/151662/1
    http://s15.photobucket.com/albums/a3...man52/Install/
    http://www.v6performance.net/forums/...ad.php?t=76937
  13. #13
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    2,250
    Re: 3-way active
    Quote Originally Posted by alphakenny1 View Post
    True, I can't imagine going for a 3 way for volume. You might as well just run a whole bunch of 2 way comps if that's your main goal.
  14. #14
    theothermike's Avatar
    theothermike is offline I HAVE NO LIFE, CA = LIFE
    May 2006
    Tampa
    1,557
    Re: 3-way active
    kenny id say go three way passive, i dont think you really have any idea how much tuning and finding your best x over point, staging and everything it will take. I going 3 way passive with my 100.4 on my cdt hd-642 and that alone will still be much much much tuning and imaging and staging. i would if i were you go with some kicker ss6's or maybe a nice set of rainbow germs or maybe some cdt m6/drt-26 tweets.
    Mike
    System:
    Fronts:ID Oem's & TBI Hdss Front Amps: Sundown Sax 100.2 & 100.4
    Subwoofer: 2x 12" Fi X D4s Sub Amps: Sundown Saz 1500D
    Headunit: Alpine CDA-9887 Batteries / Alternator: Powermaster / Mechman
    Deadener: Raamat BXT Ensolite Alarm: Clifford 50.5x
    References:
    -Premieraudio-Sundownz-Iamamp3pimp-Kpr10is-Jmanpc- MemphisLove-Greekpower-The 727 Kid-Gixxer9-Mobieous-Audiobahnuser18-Thewes-Steveyhustle-Gymfreak101-go_go_thrash
  15. #15
    BlackMaxima's Avatar
    BlackMaxima is offline CarAudio.com Elite
    Jul 2006
    LA
    852
    Re: 3-way active
    Quote Originally Posted by azngotskills View Post
    he can also use a ARC Audio MX-3, 3-way active crossover
    as a 3-way setup, and you dont realy need 3 amps for a 3way setup. you can use the MX3 and 3 amps or you can use a MX1 for a 2-way or 3-way setup.
    PS: i would say go 2-way setup, the 4chn amp you have plus the MX1 is perfect for a 2way
    PSS: go passive, its cheaper.
    HERE:
    http://www.arcaudio.com/arc-05/pdf/MX1.pdf
    References: ME,
    Quote Originally Posted by CRAZYCORNUTS18 View Post
    the JL 500/1 is good and JL actually puts out like 185% so that would be good
    Quote Originally Posted by Buffalohed View Post
    My mom is the ultimate SPL woofer.
    Cheapest too.
    Quote Originally Posted by dpom View Post
    i was wondering if this site was legit, im not sure if im allowed to post it or not so let me know if i can.
    (www.caraudio.com)
