Results 1 to 8 of 8
Reload Thread: Wiring Up Comps
    Nov 2006
    East TN
    35
    Wiring Up Comps
    I've got a set of Alpine Type X components... I've got a spare American Pro 600w 4 channel amp VS1405. I'm wanting to get rid of the distorted sound that the speakers are making, and know it's important to have the crossovers hooked up.
    If I run the amp to the preouts on the cd player, do I then just run the speaker wire from the speaker to the crossover, or does it have to go to the headunit as well?
    And is 600 watts max too much for the speakers?
    PS Not sure how to hook up the crossovers to filter out the low frequencies, but the manual gives somewhat of a 'general' idea.
    smd4life's Avatar
    smd4life is offline NOTHING ABOUT MEADE
    Feb 2006
    TN
    7,558
    Re: Wiring Up Comps
    run the pre outs just like you would....then run the speaker wire to the crossover, then from the crossover to the speakers
    it should be labeled on the crossover which one is input, mid-bass, and tweeter
    Quote Originally Posted by thevic24 View Post
    And with this.....I will use this as an excuse to drink another beer....
    __________________________________________________ __________________________________________________ ____________________________________________
    Ref's:memphissoul4u, scottiej(x3), bassaddictj, jeepinTN(x2), Blados,lincolnls(slc720052), ssbogger, stuckinok(x2), matrxx dude, BoostedPontiac, fintheman, dbornotdb, mr. tibbs, lakota, iceteebone, WantedIsHere(HypnoticCure), Cahm Rohn, Bring97, Brian Owens, snoopysnooper, sdsport92064, annarbor84, tv559, RetroAudioinc, FJF, 01 S 10, oddiofile, stupify
    sdimeconcept's Avatar
    sdimeconcept is offline Member
    Nov 2006
    East TN
    35
    Re: Wiring Up Comps
    So just wire it up to the crossover instead of the H/U? Will the only thing going to the H/U are the RCA's?
    smd4life's Avatar
    Feb 2006
    TN
    7,558
    Re: Wiring Up Comps
    yes....preouts to the amp, then from the amp use the speaker outputs...you are using an external amp right?
    Nov 2006
    East TN
    35
    Re: Wiring Up Comps
    It is an external amp.
    smd4life's Avatar
    Feb 2006
    TN
    7,558
    Re: Wiring Up Comps
    then the only thing going from the hu to the amp is rca's....
    your from athens right? me too
    Nov 2006
    East TN
    35
    Re: Wiring Up Comps
    Small world.
    smd4life's Avatar
    Feb 2006
    TN
    7,558
    Re: Wiring Up Comps
    yup...
