Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: What is the minimum RMS to drive these?
    phenryiv1's Avatar
    phenryiv1 is offline Custom user title
    Nov 2006
    Martinsburg, WV
    549
    http://www.woofersetc.com/index.cfm?...roduct_ID=4418
    I saw a link earlier and am checking now to see if they fit my vehicle. I also want to be sure that they will work with a relatively small amp.
    Thoughts?
    skadude016's Avatar
    skadude016 is offline CarAudio.com Veteran
    Feb 2003
    Canton, GA
    27
    7,319
    13
    Re: What is the minimum RMS to drive these?
    Why do the minimum?
    HU:Kenwood Excelon KDC-889
    Speakers: CDT 61A's with rainbow x-overs
    Front amp: Autotek MM100.4
    Sub amp: (2) Audiopipe 1500's
    Subwoofers: (4) 15" Crunch GPV
    Box: 16 cubes tuned to 28hz (removable port)
    Extra Batt: C&D 139AH
    151.xx sealed up 154.xx in the kick
    skadude016's Avatar
    Feb 2003
    Canton, GA
    27
    7,319
    13
    give em 100-130 and be happy
    phenryiv1's Avatar
    Nov 2006
    Martinsburg, WV
    549
    Long story short? Because I am building my system in peices, and because I don't want/need it to get loud. I don't have the space for a massive amp, and I currently have a leftover amp from an older system that will drive these until I save up more scratch to buy a new amp to run these and my (to be determined) subwoofer.
    I am trying to build a balanced system that will have about 50 watts per channel in the front and 125-135(ish) from 2 bridged channels to a single 8 or 10 inch sub.
    Since I already have a small amp, it will drive these until I decide on a sub and get a box built. After I get the box finished, I will THEN be buying a better amp to drive the frontstage and the sub. Until then, I have to run the comps off of what I have- which is an old RF amp (2000 vintage) that is either 25x2 or 62.5x2.
    skadude016's Avatar
    Feb 2003
    Canton, GA
    27
    7,319
    13
    ya the CDT's will work with that but thas jus mean to starve them lol
    just make sure you dont go clippign your amp trying to get more power
    May 2004
    Dramaville
    19,671
    Those CL series will sound good on 45rms per side and all the way up to 90rms per side. I wouldnt put more then 90 to them. They didnt like it to much when I did.
    45-50 watts is actually where I would recomend you run these if that is the power you have. Mine were respectable on that power. Another tip...deaden your doors as best as you can. This will help them out with the power you give them. Adding better, cleaner midbass, it will also help to clean up the midrange out of them.
    phenryiv1's Avatar
    Nov 2006
    Martinsburg, WV
    549
    Quote Originally Posted by jntar View Post
    Thanks for the tips. Now all that I have to do is see if they fit in my car. They fit in my budget, but I have very limited mounting depth, even with spacers.
    If these don't work, it looks like I will go with something "mainstream" like polk dBs/Momos or Quarts, because I KNOW that they will fit with the spacers.
    I planned to damp the doors when I install. I have read up a lot on deadening techniques and products and I still cannot get a handle on what will stand up to the conditions in the doors. Even the head-to-head comparisons leave me dizzy. My last damping effort (B-quiet) ended up in a puddle at the bottom of my doors, and left an adhesive residue on my windos that was nearly impossible to remove.
    May 2004
    Dramaville
    19,671
    Quote Originally Posted by phenryiv1 View Post
    Its not cheap, but take a look at the second skin products. www.secondskinaudio.com
    I use them and love them.
  9. #9
    rdzm50's Avatar
    rdzm50 is offline CarAudio.com Elite
    Feb 2006
    Indianapolis, IN
    575
    not really such a thing as a minimum
    2 Kinetik HC 2400
    Refs: AZZ-KIK-R, Louisiana_CRX, Nomad40, Xplorerdon22s, YouWantTheGrill, clkwrkorg36, TypeRBass, alxmlr789, djjdnap
  10. #10
    Hoodlum007's Avatar
    Hoodlum007 is offline CarAudio.com Veteran
    Apr 2003
    Reno Nv
    2,008
    If they dont fit you can look into these as well, very shallow mids.
    http://www.woofersetc.com/index.cfm?...roduct_ID=4894
  11. #11
    ultimate157's Avatar
    ultimate157 is offline Engineering Student
    Mar 2006
    Worcester, ma
    7,245
    The CDT's have only a 2.5" mounting depth for the 6.5" driver.
    Edit: Actually clicked the link, and those are freaking shallow.
    I'm giving mine 150w RMS and the sound amazing.
    '98 Jeep Grand Cherokee
    Source: Pioneer 880 PRS *Active
    Tweeters: 1" CDT TW-25
    Midrange: 6.5" CDT CL-65
    Sub: 15" SSA Icon
    Box: 4.0 @ 32hz
    Amp: Soundstream Tarantula 2kW
    Feedback thread
  12. #12
    luvinthebass's Avatar
    luvinthebass is offline CarAudio.com Elite
    Dec 2004
    Middle of Iowa
    28
    10,447
    Once you sound deaden you'll think to yourself, "wow, that was a good choice i made and it definitely paid off"
  13. #13
    phenryiv1's Avatar
    Nov 2006
    Martinsburg, WV
    549
    Quote Originally Posted by Hoodlum007 View Post
    Those may be the answer to my dilemma...I wonder what the depth is on those...[edit]:2.187" SWEET[/edit]
  14. #14
    phenryiv1's Avatar
    Nov 2006
    Martinsburg, WV
    549
    Quote Originally Posted by ultimate157 View Post
    I found them (the first set) from the link in your sig. The ones in the second link (the more shallow ones) will definately fit, from the looks of them.
  15. #15
    Notwerk's Avatar
    Notwerk is offline Senior VIP Member
    Mar 2004
    Miami, Fl
    31
    261
    If you need a really shallow set, look at the Exile XP components. The 6.5 set has a mounting depth of 1.85 inches. They should be in your budget.
    www.exilecaraudio.com
