Results 1 to 11 of 11
Reload Thread: Problem!! need help
    john10598's Avatar
    john10598 is offline Junior Member
    Oct 2006
    Tampa, Fl
    17
    Problem!! need help
    Idk if this is stupid problem or what but I was in my car listening be4 night school and it was all good and everything sounded fine. then after i get out i go and turn my car on and it comes on but my highs are all static and i can barely understand the words my subs sound fine but my emenince sound like shizzz.can ne one can help me out?
    jeeper07's Avatar
    jeeper07 is offline Rebuilding&Reconstruc ting
    Nov 2005
    Indianapolis, IN
    24
    7,405
    Re: Problem!! need help
    it could just be really really bad grounds...first thing i would do is check the ground on my HU... make sure my rcas dont run over my power wires... then if none of that works check into grouding the rcas better..what hu by the way ?
    http://www.caraudio.com/forum/buyer-seller-feedback/211887-jeeper07-feedback.html
    john10598's Avatar
    Oct 2006
    Tampa, Fl
    17
    eclipse cd 3000. but y would it just do it all of the sudden is what im wondering.
    john10598's Avatar
    Oct 2006
    Tampa, Fl
    17
    i re-did my grounds and ground down the paint off of where its grounded. For my hu and my amp. Could my subs be f-ed up?
    heyman421's Avatar
    heyman421 is offline Veteran Camel Master
    Jan 2006
    Akron, OH
    4,179
    low-voltage
    AJČ06's Avatar
    AJČ06 is offline 8====D ---> ( | ) = win
    Jul 2006
    DFW, USA
    10,198
    Quote Originally Posted by heyman421 View Post
    low-voltage
    Could be....
    http://www.myspace.com/unknownbelow
    Refs: Showrides|IonSQL x2|mattmcss|QtrHorse x2|DaGh0st|bjfish11
    حَتَّى إِذَا اجْتَزْتُ وَادِي ظِلاَلِ الْمَوْتِ، لاَ أَخَافُ سُوءاً لأَنَّكَ تُرَافِقُنِي. عَصَاكَ وَعُكَّازُكَ هُمَا مَعِي يُشَدِّدَانِ عَزِيمَتِي.
    Ebay:aj06silver
    Quote Originally Posted by Reson8 View Post
    Much as I shudder at the thought of potentially seeing your *****, writing caraudio.com on your dick would kick ***. Que the joke about only being able to get up to "CAR" on it....
    heyman421's Avatar
    Jan 2006
    Akron, OH
    4,179
    you don't listen to your stereo with your car off, do you? (very accusingly)
    you may wanna have your battery load-tested, coulda fried a cell
    and while you're at it, test your alternator diode, could be ripple current
    the latter would be completely coincidence, but if you're heading to autozone anyways............ may as well have them pop a dmm on there
    john10598's Avatar
    Oct 2006
    Tampa, Fl
    17
    No i dont listen to it off...but the thing is now most of the time it wont work they hit but nothing compared to what normal is when i hit bumps it sometimes it will come on good for a few seconds and it comes on when i go left. I have a bad connection obviously but i havent the slightest clue what it is. My battery is fine its got the green dot still green not yellow but alternator i have no idea.
  9. #9
    heyman421's Avatar
    Jan 2006
    Akron, OH
    4,179
    woah, time to get crazy with a dmm, check all your connections
  10. #10
    john10598's Avatar
    Oct 2006
    Tampa, Fl
    17
    Alright i think i fixed it...it was my rca from my hu 2 my amp in the back of the hu it seemed fine but i had it on rear line out so it was attached to my rear highs so i took it off and put it on non-fader out which i dont know what that is but im assuming thats eclipse's way of having a sub-out or something(explain if im wrong which i prolly am) and idk it seems to be working fine now so hopefully it was as simple as that if not im just gonna take my subs out until i get my BTL and then re-do everything.
  11. #11
    john10598's Avatar
    Oct 2006
    Tampa, Fl
    17
    ok it didnt work now i have no idea.
