Results 1 to 3 of 3
Reload Thread: How do you wire aftermarket components into factory components?
    FSUNole17's Avatar
    FSUNole17 is offline Senior VIP Member
    Jan 2005
    franklin, tn
    254
    3 Post(s)
    I am wanting to put some Kenwood Excelon dualmag components into my 98 tahoe. I am wanting to keep the factory headunit and just use the factory amp, wherever it is. The problem I have run into is that in normal aftermarket systems, there are one set of speaker wires that come from the amplifier putting out a full range signal that is then divided internally by the kenwood crossover (like all crossovers). Then 2 sets of wires (one for the tweet and one for the mid) go to the speakers, nice and clean. On the factory setup, do I have to use the factory crossover as well because the signal is already divided in the factory crossover? It appears like I will have to put in the components using the factory crossover because that is where the signal is amplified, correct? Thanks
    leonsv's Avatar
    leonsv is offline **DIABLO**
    Aug 2006
    phoenix, az
    780
    Re: How do you wire aftermarket components into factory components?
    Quote Originally Posted by FSUNole17 View Post
    ok, heres the thing... lower oem speakers like those in the tahoe have far less power than they advertise, i would guess that your amp makes 25 rms x 4 at 4 ohm at most... that is not really enough to attain full potential of your new aftermarket speakers. also, do not use the factory crossover if it has one, it is not optimized for your aftermarket speakers and would most likely sound like crap.
    this is what i would do:
    buy speakers
    buy amp
    buy line out converter
    connect loc to stock hu
    connect loc to amp
    connect amp to speakers
    this would yield much better results and should be under $500 at most for decent equipment.
    good luck
    Car Audio Wisdom
    "If everything seems to be going well, you have obviously overlooked something"
    "Silence is silver, but music is gold"
    "those who think they know everything, annoy those of us that do"
    "If you can't fix it with duct tape you have'nt used enough"
    life wisdom.... "food is tasty thus I like food"
    Notwerk's Avatar
    Notwerk is offline Senior VIP Member
    Mar 2004
    Miami, Fl
    36
    261
    I'm not familiar with the exact system in that car, so you may have to do a bit of investigating inside the door, but on many cars I've seen, the wire that leads to the tweeter has a simple inline crossover. Follow the wires from their entry point in the door, and find where they fork.
    If it's not too far a run, you can snip the full-signal cable and use disconnects from Radioshack to connect the wires to the speakers (or aftermarket crossover placed somewhere safe and weatherproof inside the door). No need for a LOC unless you want to do a full system using a stock head unit.
