Results 1 to 7 of 7
Reload Thread: Active Crossover vs Passive
    tbonephile's Avatar
    tbonephile is offline Junior Member
    Oct 2006
    Stamford, CT
    I have a set of A/D/S 346cs that I got on Ebay and I'm taking it to the shop this weekend. My installer has a Audison LRx4.300 that I'm buying from him for half price and I was wondering should I run these to the components at bridged at 210x2 (Speakers are 125 rms) or bi-amped at 65x4. If I biamp, should I go active crossover or use the passive crossovers that came with it? Whats the man difference with an active setup besides tunablity? I'm installed these in the factory stock locations of a 07 Audi A4.
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,665
    Re: Active Crossover vs Passive
    There's no sonic difference between the two...but the tuneability alone is reason to do it
    Might as well go active.
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    28
    37,876
    3 Post(s)
    i guess the first question is do you have an active xover?
    tbonephile's Avatar
    Oct 2006
    Stamford, CT
    The Audison has a lot of stuff to play with in regards to the crossover
    Oct 2006
    USA
    97
    If you run active then you have to run the amp in 4 channel mode which means less power.
    DefiantGSR's Avatar
    DefiantGSR is offline Member
    Jul 2006
    san jose, ca
    93
    active
    Notwerk's Avatar
    Notwerk is offline Senior VIP Member
    Mar 2004
    Miami, Fl
    31
    261
    That all depends. The passives might well do a good job. On the other hand, you might do better going active. Depends on how much time you want to spend tweaking. Personally, I don't see a point in bi-amping through a passive. If you're going to do that, might as well go active and get some advantage out of it.
