Results 1 to 9 of 9
Reload Thread: Trying to match sensitivities for DIY's
    yacob.naif's Avatar
    yacob.naif is offline CarAudio.com Veteran
    Jan 2006
    White Plains, NY
    4,170
    Hey gang.
    I'm getting closer and closer to finalizing my plans for my diy's components, and i had a few final questions.
    I'm curious how big of a deal a .5dB difference in the sensitivity of my tweeter and my midrange is going to be? It's a dome tweet and a dome midrange, both are morels, but the midrange is only 90.5dB and the tweet is 91dB sensitivity...
    Is this going to be a big deal?
    Will the speakers become non-linear through the volume range?
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    Re: Trying to match sensitivities for DIY's
    tweets are usually more effecient than mids. It happens, not a big deal. Just use the gains to help match sensativity. If you couldn't level match horns would be totally useless (100+db effeciency)
    yacob.naif's Avatar
    Jan 2006
    White Plains, NY
    4,170
    good point.
    i'm eskited, never heard 3-ways in a car
    and never heard a dome midrange, period
    i hope i don't hate it
    it's morel, tho, so i'm sure it's just dandy
    FoxPro5's Avatar
    FoxPro5 is offline Causal wanderer
    Aug 2005
    3 octaves higher
    5,449
    1 Post(s)
    You can make up for that either with gain or with attenuation from the HU. Compared to my midbass, my tweeters are usually -3 db and my midranges are -2 db or so. I do this through the T/A menu on my Eclipse. What HU do you run??
    TEAM Front Fill
    The Fox audiomobile now sounds more quality thanks to SDS power.
    The most expensive solution is the one that doesn't do the job correctly. ~ Me
    alphakenny1's Avatar
    alphakenny1 is offline LOTUS FTW!
    Jun 2005
    San Jose, CA
    35
    3,017
    yea as stated earlier its not too big of a deal. but if you notice something, you can adjust the gain or attenuation via your processing.
    W200/H701
    Dyn MW160/Lotus RM110/Seas Neo Alum/Idmax
    Alpine PDX
    References
    RoudyruffKK, mattmcss, BLD 25, 02corvette
    bjfish11 ,slain93gsr, DJGTSR, flakko, FoxPro5
    2.2l integra, rawdogj, guy022077, bumpn_gt
    lowlinc, rocky 59, alann, ECA, DIYMA
    bay area people need some custom work done? pm me. here's some work that we've done:
    http://www.cardomain.com/ride/151662/1
    http://s15.photobucket.com/albums/a3...man52/Install/
    http://www.v6performance.net/forums/...ad.php?t=76937
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Incase you haven't figured it out by now.....it's not a big deal
    Are you going active or passive?
    yacob.naif's Avatar
    Jan 2006
    White Plains, NY
    4,170
    i WAS gonna go passive, but i'm gonna forego my substage for a while, and spend the money to go active.
    if everything goes as planned, i should be more than happy living without a sub for a few months
    Plus, my hifonics is on ebay as we speak, so there's no turning back or changing my mind now
    thch's Avatar
    thch is offline MSEE, Design Engineer
    Jul 2005
    SIUE
    681
    1 Post(s)
    likely not. the ratings are nominal. in an app they can be a bit higher or lower based upon frequency and angle and location -- closer speakers end up being louder in most general cases.
    not more so then would be normally expected. human hearing changes across the volume range and so does the stresses on the speakers. given these two things, the speakers could exibit interactions that change with volume. but this will be minimal in normal use and can't be avoided anyways.
    -- Chris, M. Sci, Electrical Engineering
    "Ability to apply advanced mathematical concepts such as exponents, logarithms, quadratic equations, and permutations." -- job discription for senior engineer.
    "imagine paying 25 cents less per gallon for 10 gallons. that's like saving $4." --fox news
  9. #9
    yacob.naif's Avatar
    Jan 2006
    White Plains, NY
    4,170
    ya, i noticed with my last component sets that low frequencies don't tend to sound ilke they increase in volume as much as the highs and mids, so this time around i'm gonna run 4-ohm woofers, and 8 ohm midrange and tweets, so the lows have 2x the power so i'll be able to more realistically match volumes
