Results 1 to 5 of 5
Reload Thread: DIY component ???
    yacob.naif's Avatar
    yacob.naif is offline CarAudio.com Veteran
    Jan 2006
    White Plains, NY
    4,170
    DIY component ???
    I have a quick question about DIY component systems.
    Been scouting parts for a DIY 3-way component system for my audi over the last few weeks, as i've been unhappy with my kenwood 25th anniversary 6.75's (i know, kenwood, i know, i know i know, i was an idiot)
    but i digress, i'd like to keep my current 4-channel amplifier and bridge the amplifier to 2-channels, which will deliver 240w rms @ 4 ohms per door, which is more than enough, so i'm just gonna use a 3-way passive xover set
    my question is regarding the resistance of speakers
    if i have a 4ohm woofer, 4ohm midrange and a 6ohm tweeter, then what resistance will my amplifier see?
    are the resistances combined at all? Or will my amplifier see a 4 ohm load on frequencies going to the woof, 4 ohm on frequencies going to the mid, and 6 ohms on frequencies going to the tweeter?
    And if this is the case, what resistances will the amp see on in-between frequencies, that are going to two drivers (only 12db slopes)?
    thanks guys, i know it's elementary, but need to make sure, and sometimes simple questions are the hardest ones to search for
    Spud2388's Avatar
    Spud2388 is offline "The Spud-n-ator"
    Apr 2005
    Iron Station, NC
    632
    Re: DIY component ???
    If I understand you correctly, you want to run the woofers, mids, and highs off a bridged 4 channel amp? If I'm not mistaken, you don't want to do that. The proper way to run an active 3-way setup is to have the woofers off 2 channels, the mids off 2 channels, and the highs off 2 channels, using the amps crossovers or a separate crossover to limit the frequencies to each speaker. Some poeple do a semi-active setup and have the woofers off 2 channels, and then have 2 channels going to a passive crossover, which in turn sends splits the signal to the mids and highs.
    1999 Jeep Grand Cherokee
    Alpine CDA-9857 w/ iPod
    Alpine PXA-H510 (for sale)
    ED NINe.1
    ED NINe.4
    CDT CL-62 (soon to be Rainbow SLC 265 )
    (2) Alpine SWR-1242D (4.5 cuft. @ 32 hz)
    yacob.naif's Avatar
    Jan 2006
    White Plains, NY
    4,170
    passive, not planning on running them active
    just want to know how the resistances of the 3 different drivers interact at xover points
    ~Magick_Man~'s Avatar
    ~Magick_Man~ is offline CarAudio.com Veteran
    Apr 2005
    bedford,Tx
    32
    2,149
    well if the passive crossover is set to use a 6 ohm tweeter and 4 ohm other drivers everything will be okay.
    but if it was designed to use all 4 ohm drivers than a 6 ohm tweeter would mess up the tweeter crossover point.
    ~Magick_Man~
    Eclipse CD7200MKii - Memphis "Big" Belle - AudioControl DQS/DDC
    HAT L1V2 Tweeters - Focal Utopia 7W2 Mids
    DIYMA R12 x 2
    References:
    CA.com: the cybe, loserpunk, mega1268, JAZN, Digital Mint, B_Campbell, Pickup1,
    ndnbolla, jiggy2dmax, Carchrism5, JNTAR, SWEET06CAMRY, NoLimit, Mikeyboc,
    10W3dodge96, Megalomaniac, Buffalohed, Bigbirney420, Chubby, Nbudros, JrVtecAccord, flipside1212
    Icix: hificarguy, 2ndgen, Scout62, Infinity, Jet-Xino, Qalien, Hessdawg, CMILLET60
    DIYMA: SQ_Baru, danssoslow, Minivanman, Cheesehead, Starboy869, JoeHemi57, LESS
    yacob.naif's Avatar
    Jan 2006
    White Plains, NY
    4,170
    hehe, this question was hypothetical
    i just want to know what my amplifier's seeing
    i want to make sure i pick the right drivers for how much power they'll be getting/ not too much
    i mean, does the amplifier only see the resistance of the actual speaker playing that specific frequency?
