Results 1 to 6 of 6
Reload Thread: 7" references
    budahbuddy803's Avatar
    budahbuddy803 is offline CarAudio.com Veteran
    Feb 2006
    Clemson, SC
    4,700
    14
    7" references
    just saw that someone on here had some of these and said he had a nice SQ system. How are they? The truck i am getting has 4 7" speaker spots and i was looking to fill those with 7" components. What are some good SQ 7" components?
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Re: 7" references
    Depends on your budget.
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,665
    Re: 7" references
    Remember, the installation is going to make far more of a difference than the actual drivers you choose - you could throw expensive speakers in a crappy install and still have a poor-sounding setup.
    The sticky "Proper Door Sound Deadening and You" is pretty much required reading if you want to upgrade your front stage
    ballstothewall's Avatar
    ballstothewall is offline CarAudio.com Veteran
    Feb 2005
    Kansas (KSU)
    3,054
    Re: 7" references
    7" Dayton References are fricking awsome.
    Kicking the tires, Lighting the fires.
    Thieroff's Avatar
    Thieroff is offline The Master of Meatcutters
    Apr 2006
    Pittsburgh Pa
    2,710
    Re: 7" references
    You know, someone told me once
    "The better the speakers, the more important it is to have a good install"
    JimJ is right
    You can make pieces of **** sound good
    and make good equipment sound like ****
    It all depends on the install
    Sound deadening is a must when installing any speaker that you're gonna spend real money on, it may be time consuming but is totally worth it
    Your door is going to act as a "box" for the speakers, so do your best at deadening the doors and building baffles
    www.sounddeadenershowdown.com
    CT
    Pioneer880prs
    TC Sounds DB-500s
    PG Tantrum 600.4/PG Tantrum 1200.1
    CDT HDs
    Sold to :
    Vosschs, HiAmplidude, vipervin, KojiroTakenashi, BassAddictJ, SkyDeaner, Mattmcss, MaxSEma, Tapout, Playboyclic, ls2poweredgoat, amedeuce
    Traded to:
    Flaus, Lckmyblls, audiobahnuser18
    Bought from:
    FF92, Lckmyblls, DjDillioDon, Pjvoc, Mattmcss, Kasimo420,CBFryman2, BBB543, allenzo
    Thieroff's Avatar
    Apr 2006
    Pittsburgh Pa
    2,710
    Re: 7" references
    Aside from that, brands alot of people like are rainbow, cdt, diamond audio, dls, morel, and seas
    some sets are expensive, some aren't
    try running a search on here
    you're going to have a lot more options with a 6.5 set, period.
    look into building baffles or mdf rings, which are simple and give a speaker something rigid to mount to
    I made up some mdf baffles to fit 6.5's in my 5x7 spots in my doors, so guaranteed you can do it to yours
    CT
    Pioneer880prs
    TC Sounds DB-500s
    CDT HDs
    Sold to :
    Traded to:
    Bought from:
