Results 1 to 4 of 4
Reload Thread: Speaker Problem
    TheGreatMonkey's Avatar
    TheGreatMonkey is offline I'm The Monkey Master
    Apr 2006
    Somewhere
    119
    Speaker Problem
    So I go to work this morning and my front speakers are working fine. Then at lunch time, I drive home, speakers are still working fine but then they just stop working. I'm like WTF. I check all the wiring and thats okay. I check the RCA and that was okay. I hooked up my back speakers and they worked fine. The exact same way I had it when my front speakers where hooked up. I even hooked up my front speakers to my head unit and they worked. But they will not be powered by my amp. I know the channels aren't dead cause my back speakers worked fine when I hooked them up. So does anyone else have any ideas what is wrong?
    2006 Dodge Dakota ST 4x4 Black
    Headunit: Clarion DXZ785USB *Sony CDX-GT330 Temp cause UPS lost my Clarion*
    Speakers: Alpine SPX-17REF
    Speaker Amp: Kicker ZX350.2
    Sub: 2 Kicker L7 12" *2 Alpine Type R 12" Temp*
    Sub Amp: 2 Kicker 750.1 *Alpine MRD-M501 Temp*
    Sub Box: 2 4.5 CuFt @ 34Hz
    Wiring: KnuKonceptz
    Sold To: Blimblam
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    36
    13,103
    21 Post(s)
    qtipextra's Avatar
    qtipextra is offline The Original
    Jun 2004
    Idaho Falls, Idaho
    29
    5,003
    2 Post(s)
    Re: Speaker Problem
    Yup. Maybe RCA's got sliced, or something.
    Could be the RCA outs on the deck.
    Also could be wiring to speakers.
    So you hooked up your back speakers on the same channels as your fronts and they worked when you did that?
    "Big D"
    2003 Dodge Durango
    Pioneer DEH-P780MP - Pioneer USB Adapter - Toshiba 2.5" 60gb Hard Drive
    6.5" Pioneer REV Components - PG Xenon X100.2 - PG TLD66 Line Driver
    2 12" RE SE's - 4.5 Cubic feet @33 hz - RE 12.1 - KnuKonceptz 1/0 AWG Wire
    Refs: Moe Lester, Team PSI, Thisisausername, CaliforniabOY5, MikeyB, SPL140.2, hoxie08, ECS23
    My Ebay user name is qtipextra01os.
    headless's Avatar
    headless is offline CarAudio.com Elite
    Feb 2006
    Florida (Tallahassee)
    1,292
    Re: Speaker Problem
    Probably a wiring problem between the amp and the fronts.
    Hooking up the rear speakers to the fronts channels and getting sound means the amps channels are fine
    If powering the fronts off of the HU used different wires than the fronts were using from the amp (and it works on the hu) it's probably the wires from the amp to the front speakers. If it used the same wires as the amp did to power the fronts...then i am confused
    Eclipse CD7000 - RioCar Empeg 3
    Rainbow Powerline CS 275.27 / Arc Audio 4150 XXK (Woofers) - Arc Audio 2100 XXK (Tweeters)
    Rainbow Vanadium 12 x2 / Arc Audio 1500 XXK
    Quote Originally Posted by TEAM HAMMER
    Your so full of Crap! The last place you want a Midbass or Sub is in front of you Retard Whens the last time you seen a 12in+ sub up front?
    Quote Originally Posted by bdawson72
    Technically, bigger wire has more resistance.
