Page 1 of 2 1 2 LastLast
Results 1 to 15 of 29
Reload Thread: 500/1 w6v2 300/4 and what Components?
    Nexson's Avatar
    Nexson is offline CarAudio.com Elite
    Mar 2006
    Fl
    694
    hey guys I have a jl 500/1 with a 10 w6v2 and i just ordered a JL 300/4. Now I have replaced my 4 speakers with pioneers but quicky found out that the 300/4 won't do much for them due to the fact that they can't handle and dont have a high enough rms rating. Now i was planning on doing a whole jl system, but i can't afford 4 jl component speakers. What would be a good speakers to get that would be able to compliment the 300/4? and what rms should I be looking for? I need 6.5 and 6x9. thanks guys.
    Nexson's Avatar
    Mar 2006
    Fl
    694
    Re: 500/1 w6v2 300/4 and what Components?
    anyone
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    37
    8,945
    Use the ones you have an take it easy on the gains. With music, you'd be suprised how little power is really going to your speakers anyway. They should be fine.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
    Nexson's Avatar
    Mar 2006
    Fl
    694
    ok, so this is the info for my speakers, does your statement still remain the same, thanks.
    http://www.walmart.com/catalog/produ...uct_id=2569442
    http://www.walmart.com/catalog/produ...uct_id=2569441
    Nexson's Avatar
    Mar 2006
    Fl
    694
    bryantxii's Avatar
    bryantxii is offline Member
    May 2006
    midwest
    130
    dont keep the pioneers get some componets for the fronts. whats your budget?
    if your budget is real small then just get fronts, dont get rears, most say to get only fronts even if you do ahve money to spend (i like my rears). and good amount to spend on componets is around $200 for a good set of componets. if your willing to spend that much I would recommend jl xr-650csi, mb quart pce-216, cdt ef-61fg, rainbow slc 265. All can be had for around $200-250. Most will tell you to get rainbows from 6spdcoupe. if yuor budget is less than $200 then I would save up till you have enough.
    Head Unit: Alpine CDA-9885
    Componet Set: Boston SPZ
    Componet Amp: Zapco Reference 350.2
    Sub: 2 Image Dynamics IDQ10V3.D4
    Sub Amp: Zapco REF1100.1
    helotaxi's Avatar
    Dec 2003
    37
    8,945
    You can use the Pioneers until you can get componenets. They'll work fine as long as you do 3 things. First, set the gain right to prevent clipping. Second, set the highpass filter around 100hz. Third, don't go crazy with the volume.
    Because of the nature of a music signal, an amp doesn['t produce anywhere near its rated power when listening. Also your speakers don't require a lot of powr to get plenty loud with music either. Most people would be suprised how little powr is actually going to their mids and highs when playing music fairly loud. It's often only in the range of 10-15W.
    Nexson's Avatar
    Mar 2006
    Fl
    694
    ok i see what you mean, now dont mind my lack of knowledge, but i thought components are the 4 speakers, are they the four speakers, so your saying, the amp will do something for the pioneers as along as everything is set correctly, and then when i have enough $$ just buy components. is components and speakers the same thing?
    sorry .. heh
  9. #9
    Kaptain Kaos's Avatar
    Kaptain Kaos is offline Six Speeder
    Jun 2006
    Cincitucky
    Heya Nex! Saw that signature, and had to re-check what forum I was reading, heh
    The speakers you have now are coaxials. The tweeter is mounted coaxially with the woofer. In a set of components, they are mounted separately, and have an external crossover that controls what frequencies go to which component.
    I just ordered a set of Rainbow SLC components from Don (6spdcoupe). Midbass driver will go in the door speaker location, and tweeter will be 'glassed into the sail panel on the inside of the mirror.
    Depending on how you like your car to sound, you could just keep the 6x9's you have now in the rear deck. As has been said before, just set the gain carefully, your 300/4 has more power available than those speakers can take.
    A set of components up front would give you the best possible sound quality. That should be your first order of business. Once those are installed, then if you feel like you want more sound from the rear, upgrade the 6x9's next, maybe Pioneer REV series or something.
    -Kaptain Kaos
    '06 AV6 Coupe 6MT, Nighthawk Black Pearl
    In the works: JL Cleansweep, Rainbow SLCs, IDQ12
  10. #10
    Nexson's Avatar
    Mar 2006
    Fl
    694
    hehe thanks my younger brother (06) hehe, anyhow I guess ill leave the speakers in their for now and connect the amp, i know exactly where you plan to put the tweeter, i like that spot. anyhow says your in the works of a CLEANSWEEP eh? i want that, but the volume control would kill me
  11. #11
    spudracer326's Avatar
    spudracer326 is offline has a bastard system
    Jan 2006
    Oregon
    26
    1,423
    nexson are you on 7thgencivic?? eitherway talk to six speed coupe on here and get a set of rainbow slc's...they are great speakers....I wouldent worry to much about rear fill and id prolly bridge the jl to the rainbows and run the rears off the deck power if you have to have rears...in all honesty though just ditch the rear fill...
  12. #12
    Nexson's Avatar
    Mar 2006
    Fl
    694
    nah i got an accord, anyhow ill get in contact with six speed coupe, how much do they run for?
  13. #13
    Jun 2006
    Cincitucky
    Quote Originally Posted by Nexson
    Actually, it's not quite as big a deal as I had thought it was. After doing a little research on the Cleansweep and the 3Sixty, I discovered I had a bit of a misconception about the separate volume control. You can still use the volume on the factory head unit, it's just that any volume-dependent equalization built into the head unit will then start to re-appear in your sound. The signal will be a flat eq at whatever head-unit volume you tuned the processor at, but when you change the head unit volume, things such as reduction of bass level at higher volumes will come back into the signal. Bass/treble controls also continue to be effective, you tune the processor with them set to 0, then any adjustments you make from there will have their normal effect.
    -Kaptain Kaos
  14. #14
    Nexson's Avatar
    Mar 2006
    Fl
    694
    so whats a good rear fill, with around 70 rms
  15. #15
    May 2004
    Winnipeg, Canada
    125
    Lots of people will tell you to drop the rear fill thing altogether, since it makes things harder to tune and the imaging usually isnt as nice.
    I would suggest a nicer component set for the front (Rainbow SLC's would be my choice, at 230$ US from a certain fellow here on the boards ) and if you really still want rear fill from the back, just keep your old pioneers in the back and watch your gain settings.
    Alpine CDA-7995
    Rainbow SLC's
    PG Ti 400.2
    PG Ti 800.1
    Boston Pro 12.5 LF
