Results 1 to 6 of 6
Reload Thread: 99' Chevy Silverado mounting dimensions
    stealth17's Avatar
    stealth17 is offline Member
    Mar 2006
    Ohio
    36
    I have a 99' Chevy Silverado Ext. Cab without OnStar and I need to know what kind of mounting depth and hight I have to work with. Crutchfield says infinity kappa 6.5"s wount fit up front!
    I will get some adaptors for the rears....4x6 to 4" rounds.....
    Thanks
    cdj's Avatar
    cdj
    cdj is offline Member
    Jan 2004
    So. Ohio
    137
    Icon14 Re: 99' Chevy Silverado mounting dimensions
    You might find your info in this forum:
    http://www.fullsizechevy.com/
    SQChevy's Avatar
    SQChevy is offline Senior VIP Member
    Jan 2006
    Dallas, TX
    418
    1 Post(s)
    Well, one thing you can do for the rear is build your own 4x6 plate. Buy a 4" component set and mount it and the tweeter in that spot or even just a 4" coaxial on a 4x6 plate. 6.5" will fit up front because I was running them for a while, the problem with Infinity Kappa may be the magnet depth but if I recall there is plenty of room back there, they may also make their speakers a bit bigger to about a 6.75" I was running them for a while though, before I switched to JL and then Focal.
    2002 Green Chevy Z-71 Extended Cab pickup with bed cover - VEHICLE IS NO MORE
    Alpine VPA-B222 VehicleHub Pro, DVA-5210, TME-M770S, PXA-H700, KCA-100BT, TUA-T500HD
    Focal Be Tweeters, Be 6.5" Midrange, 21WX 8" Sub, 2x 40A 15" Subwoofer
    Focal 2 FP 1.800, FP 4.75
    2004/2005/2006 USACI World Champion
    2003 World Finalist
    stealth17's Avatar
    Mar 2006
    Ohio
    36
    Quote Originally Posted by SQChevy
    Well I will probably be going with these for the rears:
    http://www.cadencestore.com/ProductC...&idproduct=113
    They should be decent. Anyone ever messed with them?
    May 2004
    Dramaville
    19,653
    You can fit 7" diameter and over 3.5" with a 1/4" baffle. add depth for any thicker baffle used.
    I have 1/2 baffles and have 4" clearance.
    stealth17's Avatar
    Mar 2006
    Ohio
    36
    Quote Originally Posted by jntar
    nice, thanks for the reply!
  1. amp mounting in Chevy 2500 std cab
    By cdr in forum Wiring, Electrical and Installation Help
    Last Post: 06-02-2004, 11:16 PM
  2. Need dimensions on 95 chevy Extended Cab
    By debutis in forum Enclosure Design & Construction Help
    Last Post: 06-28-2003, 01:19 PM
  3. which sub for a 99 silverado ext. cab
    By bigtbuck in forum Subwoofers
    Last Post: 03-05-2003, 11:40 PM
