Results 1 to 4 of 4
Reload Thread: Mounting Diameter - MB Quart PCE 216
    Nov 2005
    Pohang, Korea
    47
    833
    Can someone give me the mounting diameter for the woofer in the MB Quart PCE 216's. I'm making some mounting rings out of MDF and cutting the original door locations on my Explorer to give me an exact fit.
    I have them mounted in the original location with a home made adapter over top of the factory (metal) mounting rings that were ment for the OEM 5"x7" speakers.
    Right now they look pretty ghetto, but they're covered up buy the trim panels so it doesn't matter too much, but I'm trying to get a better seal...
    2007 Pontiac Solstice GXP
    GO-N DEF's Avatar
    GO-N DEF is offline FNG
    Nov 2005
    Pohang, Korea
    47
    833
    Re: Mounting Diameter - MB Quart PCE 216
    Bump...
    FoxPro5's Avatar
    FoxPro5 is offline Causal wanderer
    Aug 2005
    3 octaves higher
    5,449
    1 Post(s)
    They are probably 165mm which equates to 6.6"....that is an educated guess having run PCE216's. Take away an inch for the cut out diameter and you're at 5.5".
    TEAM Front Fill
    The Fox audiomobile now sounds more quality thanks to SDS power.
    The most expensive solution is the one that doesn't do the job correctly. ~ Me
    GO-N DEF's Avatar
    Nov 2005
    Pohang, Korea
    47
    833
    Cool, thanks. I'll give it a try. I'm still loking for the tech sheet that came with them. I usually keep **** like that, but its not in my files any where...
  1. MB Quart PCE 216 vs JL Audio XR 650 CSI
    By 1600dave in forum Speakers
    Last Post: 02-16-2006, 07:43 AM
  2. mb quart pce 216 power handling?
    By hellbender in forum Speakers
    Last Post: 09-23-2005, 03:06 AM
  3. Replies: 2
    Last Post: 06-23-2004, 04:04 PM
