Results 1 to 6 of 6
Reload Thread: 8" Speaker recommendation
    Quiksilverdad's Avatar
    Quiksilverdad is offline Junior Member
    Jan 2006
    Annapolis, MD
    Looking for your comments.
    I'm looking for an 8" (round) woofer, or mid-bass woofer with decent midrange response to at least 2,500 or more (-3db). They will be mounted low in the doors and firing straight across the legs. My tweeters are mounted right below the window, at head(?) level. I do like the tight bass of a crisp drum roll, and am missing the voice mid-range up front from what I have now. My rears are kicker 6.0" and are quite satisfactory. Price range no more than 150-200 / pair.
    I have been looking at:
    Pyle
    Audax
    Lanzar
    Tang Band
    Can't find many 8" speakers, but I would like them because they will give me enough low bass for my needs. Sorry about the lack of full details, but i'd rather focus on speaker brand recommendations than my system setup. (Car is a Miata).
    Thanks.
    FoxPro5's Avatar
    FoxPro5 is offline Causal wanderer
    Aug 2005
    3 octaves higher
    5,450
    Re: 8" Speaker recommendation
    I heard some Kicker SS's the other day and thoroughly enjoyed them
    TEAM Front Fill
    The Fox audiomobile now sounds more quality thanks to SDS power.
    The most expensive solution is the one that doesn't do the job correctly. ~ Me
    pwnt by pat's Avatar
    pwnt by pat is offline Pat for Prez 2024 - vote!
    Sep 2004
    Pa
    25
    2,179
    An 8 that will play that high would probably be pretty rare. The Adire Koda will play higher than 1khz and the id8 in sealed will play up to 1khz also.
    (I just want to see what the other guys have to say - squeak, list those 10 wide-range drivers of yours)
    carputer - h701 - c701 - dynaudio mw170s - si mag 15 - ss rubicon 604 x2 - ss rubicon 1002
    coming soon:
    seas w15cy - alpine spx177r tweeters
    djdilliodon's Avatar
    djdilliodon is offline CarAudio.com Elite
    Dec 2002
    New York
    658
    aurum cantus 200mk2 but i recommend u run them sealed.
    Contacts:
    email - islandsound1@yahoo.com
    AIM - djdilliodon
    05 SRT-4
    System in the works
    MIDBASS ?
    FE3T's Avatar
    FE3T is offline Junior Member
    Jan 2006
    Norway (Europe)
    Check out Morel USA`s WR-8 or Morel Israel`s HCW or Elate 8
    On Ebay it could also be wise too search for Macrom 59.21, 59.22 or Macrom Integra W-224. (the W-224 are what i am using as midbass, IB in doors)
    All of the above mentioned speakers work well IB, have shallow installation depth (52-64mm) and can be used in 2 way systems with 3k-3,3khz upper xover
    UndercoverPunk's Avatar
    UndercoverPunk is offline Super Mod
    May 2004
    Dayton, OH™
    15,663
    Caraudio.com - Where the average member couldn't wire a SPST toggle if they had to.
    More proof.
    Quote Originally Posted by Andrew_as View Post
    I need a program or something that will help me find mounting depth without having to build box and such...
    No, Andy, I'm sure the context is fine.
  1. wow...
    By Black_Jesus in forum General Discussion
    Last Post: 09-23-2004, 11:54 PM
  2. speaker recommendation needed
    By mr personality in forum Speakers
    Last Post: 09-21-2004, 10:45 PM
  3. Grand Cherokee speaker help
    By hooppro in forum Wiring, Electrical and Installation Help
    Last Post: 08-28-2004, 08:24 PM
  4. Will different speaker wire lengths cause problems?
    By loudfivepoint0 in forum Wiring, Electrical and Installation Help
    Last Post: 08-16-2004, 10:38 AM
  5. Why 4 awg power, and 16awg speaker wire?
    By ngsm13 in forum Wiring, Electrical and Installation Help
    Last Post: 05-13-2003, 08:06 PM
