Results 1 to 5 of 5
Reload Thread: Turning a 4 channel into a 2 channel
    KyleScha's Avatar
    KyleScha is offline Member
    Dec 2005
    VA
    41
    Ok. This is probably a bit of a newb question. I have a JL300/4 and wondered what would happen if I ditched my rear speakers and made it 150x2.
    So I just want to make sure what I did is effectively putting out 150 watts on each speaker.
    What I did was bridge the two front channels for the right speaker only, and only plug in the right RCA. I did the same for the rear channel, except I bridged it using the left speaker only. I then plugged the left RCA cable into the left.
    Now as long as I keep the gain and crossovers the same, is there anything wrong with this and am I getting 150 watts to each speaker?
    Thanks.
    KyleScha's Avatar
    Dec 2005
    VA
    41
    Re: Turning a 4 channel into a 2 channel
    blah, i posted this into the wrong forum sorry
    ToyTundra's Avatar
    ToyTundra is offline has a slanted soundstage
    Jan 2005
    AZ
    938
    it may be a noob question, but you have the right answer. You are my favorite of all the members
    There is nothing wrong with it at all.
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Sounds like you did a good job.
    And yes, you are getting 150w per side.
    KyleScha's Avatar
    Dec 2005
    VA
    41
    Thanks for the kind replies!
    It sounds amazing!
  1. HELP: Can you wire 2 speakers to 1 channel??
    By groov2 in forum Amplifiers
    Last Post: 04-07-2005, 07:41 PM
  2. 1 Channel or 2 Channel
    By U n r e a L in forum Amplifiers
    Last Post: 03-23-2005, 04:22 PM
  3. channel positions
    By joker7 in forum Wiring, Electrical and Installation Help
    Last Post: 02-27-2005, 03:36 PM
  4. 4 channel amp question, sub output
    By outbacksport in forum Amplifiers
    Last Post: 05-31-2003, 09:27 PM
  5. Replies: 1
    Last Post: 07-29-2002, 10:40 AM
