Results 1 to 2 of 2
Reload Thread: dont know how to power components
    cooldudejz's Avatar
    cooldudejz is offline Senior VIP Member
    Jul 2005
    N.H.
    192
    i am very confused on how to power my component set. i dont know whether to use a 2-channel or a 4-channel amp, and how i would use them. say if i had a 2-cahnnel amp that put out 200x2 at 4ohms. if i connected this to the x-over would this blow the speakers if they are rated at 80watts. i mean would the right wattage go to the midrange/tweeter. as you can tell i am very confused any help is greatly appreciated
    FoxPro5's Avatar
    FoxPro5 is offline Causal wanderer
    Aug 2005
    3 octaves higher
    5,449
    1 Post(s)
    Re: dont know how to power components
    Quote Originally Posted by cooldudejz
    No you won't blow them up and yes the right wattage will go to the right speaker - that's why it called a crossover. Most likely they came with jumpers that connect the imput on the woofer and the tweeter together...In this case you would just wire your +/- from your amp to the +/- on the woofer connections on the x-over.
    TEAM Front Fill
    The Fox audiomobile now sounds more quality thanks to SDS power.
    The most expensive solution is the one that doesn't do the job correctly. ~ Me
  1. *amplifiers/power ratings*
    By dbhittin in forum Amplifiers
    Last Post: 06-30-2008, 11:33 PM
  2. Power & Torque
    By Acidburn in forum Car Performance and Repair
    Last Post: 04-26-2005, 05:34 PM
  3. will this amp be enough power for 2 15's?
    By bang hard in forum General Discussion
    Last Post: 03-02-2005, 02:44 PM
  4. too much power???
    By chopstick1981 in forum Speakers
    Last Post: 07-14-2003, 08:15 AM
