Results 1 to 12 of 12
Reload Thread: Anyone mess around with different power levels going to DLS Iridium
    Intercooler's Avatar
    Intercooler is offline CarAudio.com Elite
    Sep 2004
    Maryland
    1,163
    6.2's? Wondering what range worked best with them?
    2001 Honda Civic EX Coupe
    HU- Eclipse CD-5000
    F&R Amp- MB Quart Qaa4250 1000 Watt 4-Channel
    F- CDT HD52 5.25" With 1" Silk Tweets and M-6 6.5" Mids In The Doors(Three Way)
    R- CDT M-6's
    Sub Amp- Hifonics BXi2006D Brutus 2000 Watt D Mono
    Subs- (2) FI-Q 12" in a 1.26 Cu^Ft./Per Side Unported Box
    Battery- Kinetic 1400
    House- Samsung 4665F/Def Tech Mythos 8's/Dayton 15" Sub Kit/Onkyo 605/Harmony 890
    Refs: B-06stxf150, S-tmcilroy, B-lastcall
    Ignatowski's Avatar
    Ignatowski is offline CarAudio.com Veteran
    Mar 2005
    Dirty South
    6,857
    Re: Anyone mess around with different power levels going to DLS Iridium
    underrated,and loves alot power
    200+
    Sep 2004
    Maryland
    1,163
    Will they handle 275W?
    HU- Eclipse CD-5000
    R- CDT M-6's
    Sep 2004
    Maryland
    1,163
    How about 205W? Anyone on here have a set of Iridiums up and running? If you do then how much power are you putting to them?
    HU- Eclipse CD-5000
    R- CDT M-6's
    dflock's Avatar
    dflock is offline Member
    Dec 2003
    Rhode Island
    101
    I've got a set in Kick Panels. Powered by a US Amps TU-600. Thats 150watts RMS x 2 (at 12.5 volts). So I figure they see about 175-180 watts. They are crossed at 90hz.
    Never had any problems and could probably run at 200 watts RMS as long as they are not run full range and have proper crossover.
    FoxPro5's Avatar
    FoxPro5 is offline Causal wanderer
    Aug 2005
    3 octaves higher
    5,450
    What's the sensitivity on the Iridiums? If you were going to put that MBQ in your sig on them, I think you'd have a great combo. Put as much clean power on them as you can afford!!!
    TEAM Front Fill
    The Fox audiomobile now sounds more quality thanks to SDS power.
    The most expensive solution is the one that doesn't do the job correctly. ~ Me
    thefunkybunch's Avatar
    thefunkybunch is offline Senior VIP Member
    Oct 2005
    cloud9
    32
    282
    put as much clean power to ANY component set as you can afford. it never hurts to have sick amounts of headroom
    Sep 2004
    Maryland
    1,163
    I am still learning here and think I just made my first boo-boo last week. I put that MB Quart amp in my Honda going to the Focal 6x9's and my CDT components. The 6x9's are blazing away and sound just wonderfull. The CDT 5.25" mids also are booming away nicely. The CDT tweets were sounding just utterly amazing then.... pop .... they stopped playing! They are out now for service but I think we found they blew. I am looking into some protection for them but don't really know what happened other than too much power going to them. I was on a quest for power up until that point. It kept responding so I kept giving it but now I have to figure out how to prevent it.
    The Iridiums are for the truck listed. I am amp poor right now as I have a 800.4 and a 550.2, both by Kicker. Of those only the 550.2 qualifies for the task of powering the Iridium 6.2's but if my math is correct it will give me 205W per side @4 Ohm. The spec in their sheet says like max power of 150W and RMS of 100W. I can't/don't want to destroy another set of tweets again. The CDT's were 160 RMS and I killed their tweets with 250W. I need to figure this out before I F-up again.
    HU- Eclipse CD-5000
    R- CDT M-6's
  9. #9
    scarysoul's Avatar
    scarysoul is offline Senior VIP Member
    Oct 2005
    Brunei
    33
    199
  10. #10
    scarysoul's Avatar
    Oct 2005
    Brunei
    33
    199
    ok... nvm my first question... but if i combined two of the thunder 5302... will that be ok? or should will Lanzar Opti200X4 will be better?
    http://www.lanzar.com/itempage.asp?MODEL=OPTI200X4
  11. #11
    Eugenics's Avatar
    Eugenics is offline Princess
    Jul 2005
    Arbys
    23,934
    im about to be pushing 100 to mine haha. ive heard of ~250-300 being pushed to them without fail. however i would never put that much to them. 200 seems safe though. talk to tim french he could help you out quite a bit (his fourm name is tplaya07) i bought mine from him and he's been an amazing help. im sure he'd be willing to lend you some advice as well
    crunktimes . com/ct
  12. #12
    scarysoul's Avatar
    Oct 2005
    Brunei
    33
    199
    ok ok ok... since most ppl disagree with me using an mtx amp, so guess i have to change my setup design now... i hope this will be the last choice of amp... eheh...
    Alpine MRV-F545
    http://www.alpine-europe.com/content...-AMPLIFIER.htm
    Alpine MRV-F345
    Rockford P6002
    http://www.rockfordfosgate.com/produ...5&locale=en_US
    Rockford P8002
    http://www.rockfordfosgate.com/produ...8&locale=en_US
    Kickers SX600.2
    DLS Ultimate A3
    DLS Ultimate A8
    bear in mind i dont wish to overpower the iridium... i only need enough watt to give some clean power at them... and it would be best if someone can tell which amp goes first and which amp is the last one to use... thanks...
  1. Box for RE XXX?
    By ls1pimp in forum Enclosure Design & Construction Help
    Last Post: 07-29-2005, 01:31 PM
  2. Replies: 2
    Last Post: 02-18-2005, 07:42 PM
  3. Dls Iridium 6.3 Vs Seas Lotus Reference
    By IHFJ05 in forum Speakers
    Last Post: 01-11-2005, 05:34 PM
  4. Phoenix Gold Elite or DLS Iridium 6.2
    By johan184 in forum Speakers
    Last Post: 01-11-2005, 12:37 PM
  5. Power and ground from amp, so I only need switched power to head?
    By Snail in forum Wiring, Electrical and Installation Help
    Last Post: 02-26-2003, 05:06 PM
